Oil Field Engines
Back on the Ajax again
this thread has 70 replies and has been viewed 12815 times
Old 09-21-2006, 11:39:54 PM
KeithW's Avatar
KeithW KeithW is offline
Photo Back on the Ajax again
Hello all,
Finished uo a couple of other chores and started working on the Ajax 7 1/2 x 10 again. Here's how it looked when I uncovered it.
http://members.aol.com/keith0alan/images/ajax22.jpg
Took a bunch of bits off but it got dark before I could get another picture. I'll get one tomorrow. Hope to have it all apart within a week. Then I'll clean and paint the crank case. Once that's done I can say that I'm in the reassembly stage. Not that the other parts can go back on till they are cleaned. There is a lot to like about this engine. Not too many parts and they are all real big. Once the rusted up side shaft stuff was loose it turns over very smoothly and easily.
keithw
Old 09-22-2006, 09:39:20 PM
Patrick McNallen Patrick McNallen is offline
Default Re: Back on the Ajax again
I just acquired a Superior type CM 6 1/2 X 8. According to the brass tag, it was "Manufactured by National Supply Company, Superior Engine Division, Springfield, Ohio. Made In U.S.A" <p> It looks almost exactly like your Ajax, including the clutch and water pump. The cast clutch arm was apparently broken at some point and replaced with a welded up plate steel subsitute. It seems to work OK, but I'd really like to find an original cast bracket that would fit. It doesn't give a horsepower rating, but I figure it's in the 16 to 18 HP range. I also got an Ajax EA 22 of about 1974 vintage from the same seller. It is 22 HP, and the same bore/stroke as the obviously much older Superior, and runs at 350-650 RPM instead ofthe 300-600 RPM of the older engine. The newer Ajax has a very similar frame and general layout to the older one, but the peripherals are all different in detail, and the older engine has a much lighter flywheel that looks more like a typical antique hit-miss engine. The newer Ajax has a massive flywheel that is typical of all "modern" Ajax engines that I have seen, and it has an electric starter and Twindisc type clutch. The old engine doesn't have any kind of starter, nor does it have a place for a crank to fit, but it does have a cover plate on the cam box that suggests that an air-start rig may have been available for it.
Old 09-23-2006, 02:18:33 PM
KeithW's Avatar
Photo Re: Back on the Ajax again
Well, here's a picture with most of the easy stuff taken off.
http://members.aol.com/keith0alan/images/ajax23.jpg
The flywheel is being a chore. That is a Simplex railroad jack that was used to lift rail cars and such, a serious screw jack. I'm heating things up with the 80,000 BTU/HR turbo jet engine space heater. It's not off yet but I expect to get it today.
http://members.aol.com/keith0alan/images/ajax24.jpg
The later Ajax engines had an optional air start and even later had an optional electric start. The older ones were either hand started by turning the flywheel or with an external electric starter that had a rubber wheel that ran on the outside of the flywheel. I think that I will put together a 5 horse Briggs and some mini bike bits to make a starter cart thing.
This one is rated at 400 RPM for 20 HP. The more modern version is 600 RPM and 30 HP. The older Ajax also did away with the water pump and simply thermosyphened. Seems the pump wasn't really necessary.
keithw
Old 09-23-2006, 10:32:51 PM
KeithW's Avatar
Talking Re: Back on the Ajax again
Oh happy day . After about five gallons of propane and some hard cranking the flywheel moved. Only about a quarter inch, but, as we know, that first bit means you're home free. I'll get the engine crane to hold it up and jack it the rest of the way off tomorrow. Then the rest of the clutch comes off and into the guts I go.
keithw
Old 09-23-2006, 11:17:14 PM
Jordan's Avatar
Jordan Jordan is offline
thank you very much ketih for keeping us up to date on your progress on your ajax and i can't wait to see the pictures when it is all done. are you writing a story for G.E.M. about the restoration?
jordan
Old 09-24-2006, 07:34:04 AM
KeithW's Avatar
I'm having fun with it and don't mind sharing. Hadn't thought about writing an article. I'll try to keep the documentation up so that can be an option.
keithw
Old 09-24-2006, 07:48:09 AM
DanR
The space heater is a great idea. I'm going to try it. Are you directing the heat to the outside rim or is it just the camara angle?
Keep us posted on this. DanR
Old 09-24-2006, 04:24:37 PM
Kyle McGee's Avatar
Kyle McGee Kyle McGee is offline
hi keith
just woundering if you ever go the piston un stuck on that ajax
Old 09-24-2006, 10:02:22 PM
KeithW's Avatar
I did get the piston unstuck. Took the piston and cylinder to Oklahoma City on my trip in the spring and had the cylinder sleeved. It's slightly under size to allow for the piston wear.
The heater is pointing at the rim. If you just heat the hub the spokes get longer, push against the rim and make the hub tighter. Heating the rim expands it, pulls on the spokes and loosens the hub. I just kept turning the flywheel a bit every half hour or so till the entire thing was warmed up from the outside in.
The flywheel came off early this AM . When folks talk about things weighing a ton they usually are streaching it a bit. This thing may not weigh a ton but I bet it's not far off. More than a little scary to handle. And it wouldn't have the decency to kill you outright. It would pin you to the ground and make you suffer for a while.
http://members.aol.com/keith0alan/images/ajax25.jpg
Cup o hot tea at the ready it's time to attack the side shaft stuff.
http://members.aol.com/keith0alan/images/ajax26.jpg
big gears and big bearings
http://members.aol.com/keith0alan/images/ajax27.jpg
Connecting rod, cross head and piston rod seal. The con rod big end and small end bearings are in good condition. Most things are coming apart pretty easy. The ones that aren't are being a real pain.
http://members.aol.com/keith0alan/images/ajax28.jpg
It's getting there. The clutch is being the afore mentioned real pain.
http://members.aol.com/keith0alan/images/ajax29.jpg
View from the cylinder end, past the cross-head slide and out the back
http://members.aol.com/keith0alan/images/ajax30.jpg
Next is getting the clutch off. Then some serious pressure washing and out comes the crank. It's looking like the inside will only need a good cleaning and then reassembly. Some ( alright, all) of those bearings look like they would be pricey to replace.
keithw
P.S. That's a friends Aeronca Champ, built in 1946. He's borrowing a bit of space to do a some of work on it.
Old 09-25-2006, 04:44:02 PM
KeithW's Avatar
Doing the Egyptian thing to move it across the patio to start cleaning. The clutch is being a real bear . Figured I'd start doing some cleaning between working on it.
http://members.aol.com/keith0alan/images/ajax31.jpg
It seems like the big gear on the flywheel side just slides on. Can anyone confirm or deny this? It's not loose but hopefully a little heat will free it up.
keithw
New Ajax 5 X 6 1/2 Chuck Ostrander Oil Field Engines & Related Equipment 5 11-06-2009 11:52:23 AM
12 X15 Cm Ajax Bill Geyer Oil Field Engines & Related Equipment 69 05-22-2009 09:56:39 PM
Ajax 8.5 x 10 Weldengineer Oil Field Engines & Related Equipment 6 08-16-2008 09:14:57 PM
AJAX Video Bill Geyer Oil Field Engines & Related Equipment 0 06-25-2007 04:32:10 PM
AJAX generator Dan A Generators & Electric Motors General Discussion 6 07-12-2005 11:05:58 AM
