kohler k-series engines
this thread has 4 replies and has been viewed 4311 times
Old 09-28-2006, 06:50:55 PM
AZick AZick is offline
Default kohler k-series engines
Hi,
I was wondering if someone on this list would have specs for Kohler k91, k121, and k141 horizontal engines? I am looking for information on how much the engines weigh, and the bolt pattern they have (on the bottom of the engine). I am looking for a replacement engine for a troy-bilt pony rototiller (it was a very early troy-bilt pony and had a 4hp Briggs engine, which was then upgraded to a 5hp). I have put several engines on it and it seems like the newer the engine, the less it lasts. So, I want to find something that is older (better built). Any information that you could give me on the k-series engines (or where to locate one) would greatly be appreciated?
Thanks,
Al
Old 09-28-2006, 09:55:49 PM
Terry Beasley's Avatar
Terry Beasley Terry Beasley is offline
Default Re: kohler k-series engines
Check Kohlers site in the classic engine area. They have the manuals for downloading.
http://www.kohlerengines.com/onlinec...lsfam=K-Series
Old 09-29-2006, 02:40:56 AM
ListerDiesel's Avatar
We put up a lot of Kohler brochure pages along with the generator stuff at:
http://www.oldengine.org/members/die...ler/Kohler.htm
Have a dig though there, we have more to scan yet, let me know if you cannot find what you need.
Peter
Old 09-30-2006, 03:54:05 AM
Samuel.G Samuel.G is offline
I have the kohler K161c (the "c" at the end means it had a clutch"), it needs a new head gasket, but apart from that, it runs really well. I got the manual off the kohler webpage
Old 09-30-2006, 08:27:21 AM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Images: 2
Hello, Try a good Kohler engine dealor before you put too much time in your search.. when I worked at the dealorship ( 1978-1994 ) there was a cross ref. sheet in our sales book that would cross Briggs, Tech, Wisc. engines to Kohlers.. that will give you the series numbers to look for.... Good luck !
Randy Hart Ohio
Lucky with the Briggs F series Engines K.Watkins Small Air Cooled Gasoline Engines 11 01-27-2010 12:23:39 AM
Case R Series Engines (RE Engine ??) Bud Tierney Antique Farm Tractors 3 03-23-2008 07:32:57 AM
Looking for voltage regulator for Kohler K series moto-forge Magnetos, Ignition Coils and Spark Plugs 9 10-24-2007 10:54:22 AM
asco series 165 automatic transfer switch with kohler rmk62 generator DannyD Kohler Generators 7 02-25-2006 12:44:14 PM
WTD: Generators W/Briggs F series engines John Rolli Generators & Electric Motors General Discussion 0 06-09-2002 01:55:46 PM
