Homemade Push Rods
this thread has 5 replies and has been viewed 2548 times
Old 10-10-2007, 07:43:27 AM
Virginia Mike Virginia Mike is offline
Default Homemade Push Rods
Will mild steel rod from the hardware store do to make push rods for a IHC LA?
Thanks,
Mike
Old 10-10-2007, 07:55:01 AM
Doug Kimball's Avatar
Doug Kimball Doug Kimball is online now
Images: 78
Default Re: Homemade Push Rods
Mike,
Should work fine.
Old 10-10-2007, 09:11:51 AM
Gerry Boose's Avatar
Gerry Boose Gerry Boose is offline
I bought a set from Hit and Miss Enterprises for about $15.00. Is it worth while trying to make them?
Old 10-10-2007, 08:08:25 PM
George Vaughan's Avatar
George Vaughan George Vaughan is offline
Thumbs up Re: Homemade Push Rods
Soft is not all bad....I have a fairly soft stainless homemade push rod on a large engine that has to stay covered up outside all year.....went to start it after it had been sitting a while and did not realize that the exhaust valve was stuck....that stainless rod flexed and saved me from having to replace a rocker arm.
Old 10-11-2007, 07:59:21 AM
3 feet of rod is less than $10 at the hardware. I'm retired, low money, lots of time. If I'm not doing this I'll be scouring fence rows trying to buy me another job.
Best,
Mike
Old 10-11-2007, 08:18:36 AM
vern0n's Avatar
vern0n vern0n is offline
I used mild steel rods in my LB. No problems so far.
Can Anyone ID These Bronze Connecting Rods? Chris Lewis Antique Gas Engine Discussion 5 01-19-2008 07:26:17 PM
AC/DC Question About Rods Holland501 Welding Shop 2 10-16-2007 06:32:32 PM
onan CCK 4.0 3cr rods neded NAScrew Onan Generators 2 02-18-2005 11:31:37 AM
onan Gen help rods and crank NAScrew Onan Generators 0 02-08-2005 01:15:26 AM
onan rods and crank.. NAScrew Onan Generators 0 02-08-2005 01:07:33 AM
