Model Hit&miss Engine
this thread has 1 replies and has been viewed 2035 times
Old 11-07-2007, 11:48:21 PM
Jerry B Jerry B is offline
Default Model Hit&miss Engine
Where Is A Place To Get Cast Iron To Make 8" To 9" Flywheels For Models, And How Is The Best Way To Fasten Them To The Crankshaft, I Have Had Troubles With Them Comeing Lose. Jerry B
Old 11-08-2007, 12:01:08 PM
David Tsr David Tsr is offline
Email Not Working
Default Re: Model Hit&miss Engine
Jerry I use a tapered key just like the full size engines or a split hub with a bolt and key like on the 1/2 size Domestic model. As for cast iron flywheels several model suppliers have different sizes available.
Try posting this question on the Scale Model Engineering Forum I am sure you will get many more suggestions and ideas David Tsr
Scale Model Hit&Miss Engine Kits actionhac Scale Model Engineering 3 03-28-2008 10:03:59 PM
Stickney 1 3/4 Hp Precision Scale Model Hit Miss Engine Tim Venetis Scale Model Engineering 4 11-04-2007 02:11:19 AM
IHC Hit & Miss model of a 20HP Tractor engine Paul Spence Antique Gas Engine Discussion 0 09-11-2007 08:39:01 PM
Model Hit&Miss Engine cylinder bore Jerry B Scale Model Engineering 8 04-30-2007 10:56:32 AM
building a Model from a hit and miss engine Beau Nelson Antique Engine Archives 2 05-29-2002 05:26:21 PM
