Maytag 72 Carburetor
this thread has 3 replies and has been viewed 2524 times
Old 06-20-2008, 11:48:32 AM
Chris Quattlebaum Chris Quattlebaum is offline
Default Maytag 72 Carburetor
Hello folks,
I am new to this board and am just getting into the antique part of the hobby. I have been "messing around" with small engines for many years, but not older ones.
I am looking at a model 92 and a 72 (72D or twin). My question is: where is the carburetor located on the 72? I want to make sure these engines are complete before I buy...
I have exhaused the search feature here and looked on the web.
Thank you for your help in advance. There is so much good information here.
Chris Quattlebaum
Old 06-20-2008, 12:22:23 PM
KeithW's Avatar
KeithW KeithW is offline
Default Re: Maytag 72 Carburetor
There is no carb as such on the 72. The functions are spread about. The mixture is controlled by the big knob. The mixing is done at the bottom of the crankcase. The throttle valve is inside the crankshaft. It's hard to tell if all the bits are there without either running it or taking it apart.
keithw
The Following User Says Thank You to KeithW For This Post:
Old 06-20-2008, 01:20:47 PM
Thanks, Keith. Right now, all I have to go by is pictures. I would guess that all the internal stuff is there, but I suppose going to look at it is the best bet. Thank you for the help!
Chris
Old 06-20-2008, 02:14:52 PM
Francis Francis is offline
Here is a good link with Maytag detail drawings - http://www.oldengine.org/docs/Maytag_SM.pdf
The Following User Says Thank You to Francis For This Post:
Carburetor Kit help egeschwill Kohler Generators 6 05-24-2008 02:11:05 AM
Carburetor Jerry B Antique Gas Engine Discussion 1 11-26-2007 04:06:30 PM
Will Maytag 72 power my Maytag washing machine. triplepass Maytag Engine Collectibles 9 11-14-2007 12:52:04 AM
B&S Z Carburetor Ralph Leonard Small Air Cooled Gasoline Engines 6 07-18-2005 06:59:27 AM
Maytag 92 carburetor set screw Brent Wegher Antique Engine Archives 1 10-31-2003 08:38:14 AM
