Maytag Weekend Project
this thread has 5 replies and has been viewed 1688 times
Old 11-09-2008, 02:42:42 PM
MaytagRepairMan's Avatar
MaytagRepairMan MaytagRepairMan is offline
Default Maytag Weekend Project
My 82/92 Maytag....
Well just finished my weekend project. Not telling how many weekends...
I built this from spare parts that I have had laying around. I did find some differance in some of my parts. I have posted some phots for you to look at it. The long base is listed as the same part # but look close, these were the long bases for the first Model 92 Washers. So can someone tell me which is the oldest??? I have also posted a YouTube video for you all to see and hear her run. Still have some bugs to work out..as it only wants to only run for about 30 sec and then floods out.
Tell me what you think.
David
http://www.youtube.com/watch?v=8jGHz6RKD6w
ID:	42974   Click image for larger version
ID:	42975   Click image for larger version
ID:	42976   Click image for larger version
Old 11-09-2008, 03:02:26 PM
terry tabb terry tabb is offline
Default Re: Maytag Weekend Project
not to bad , have you tried screwing the jet in 1/2 turn it will smoth out or leave it alone when you got a mole you what to get rid of stick the hose in his hole he come up for air , that what an old timer said he did, get rid of them ,
Old 11-10-2008, 12:30:55 AM
Andrew Mackey Andrew Mackey is online now
Thumbs up Re: Maytag Weekend Project
I tried that when I first bought my house. Had a 92 that smoked like the dickens. I jambed the exhaust pipe in a mole hole, and let her rip for about 20 minutes. When I came out, smoke was pouring out of about 10 holes in my yard, and a neighbors as well. Didn't see no moles, but didnt get any more holes either! Works on chipmunks too!
Old 11-10-2008, 01:29:35 AM
Tom S's Avatar
Tom S Tom S is offline
That is neat. I have done that on a couple too and it makes a good show piece on its side like that.
Here are three different 92 tanks plus the long base twin tank. The chrome one is the earliest, followed by the one that is harder to see, and then the curved one is the last long base style used on the single cylinder. The remaining one is the long base twin front end.
Old 11-10-2008, 06:17:45 PM
CJBennett CJBennett is offline
How do you get away with turning 90 degrees? Do you use a 82 piston or something?
CJ
Old 11-10-2008, 11:13:24 PM
Tom S's Avatar
How bout it David, Did you use an 82 piston or the 92 piston?
I used 82 pistons in the ones I did. Took a die grinder and carved a tranfer port on the corresponding place on the crank case to let the fuel charge enter the cylinder.
Will Maytag 72 power my Maytag washing machine. triplepass Maytag Engine Collectibles 9 11-14-2007 12:52:04 AM
Fun Weekend Christopher Markley Antique Gas Engine Discussion 2 12-06-2006 04:51:17 AM
4.0BFA spec D weekend project RWiesner Onan Generators 3 04-06-2006 07:23:58 AM
maytag project brian Antique Engine Archives 0 09-02-1999 08:29:08 PM
