Oil Field Engines
1945 Fairbanks-Morse, cannon type
this thread has 41 replies and has been viewed 5999 times
Old 09-17-2009, 05:41:35 PM
Jim Gorter Jim Gorter is offline
Default Re: 1945 Fairbanks-Morse, cannon type
Larry, to clean up the bore on topside of piston,use a wire wheel on a hand drill. Dont be too concerned with the pitting until you get it cleaned up. Most times, the larger engines will run with conciderable blowby. If real bad you will need to look into boring and sleeving the cylinder. Very hard to hone the pits out and then you will need to find an oversized piston to fit the larger bore.
I'm not sure if the piston/rod will come out the back. If you can, unhook the rod from the crank and make sure the crank and gearing are loose. Other wise you may break something while you are trying to remove the piston. Good Luck, Jim.
Old 09-17-2009, 06:19:00 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
there is a trick with these types of engines that i have used well for my hit miss engine anyway i just used jb weld in the cylender bore to get rid of the pitting. I dont know if you want to do something like that but it might be an idea to try. But if you want to try is you fill in the pits with jb then hone and your ready to go just make sure there is no oil or anything in those pits so you get the best bond to the metal. and make sure you let it dry for a week.
Fairbanks Morse 4hp type Nate Antique Gas Engine Discussion 20 11-24-2005 07:38:51 PM
12 hp Fairbanks Morse type T Mike Buck Antique Gas Engine Discussion 3 01-03-2005 11:11:41 PM
Fairbanks Morse Type T Jason Dahm Antique Engine Archives 0 02-01-2004 12:00:21 AM
Fairbanks Morse 1945 Larry Reinhart Generators & Electric Motors General Discussion 1 04-16-2003 11:55:58 AM
Fairbanks-Morse Type H Dave Huling Antique Engine Archives 0 10-22-2002 08:41:26 PM
