Oil Field Engines
*** De La Vergne Project ***
this thread has 80 replies and has been viewed 13971 times
Old 11-10-2009, 11:49:30 AM
BuckeyeMan BuckeyeMan is offline
Photo *** De La Vergne Project ***
Starting a restoration project for a 35 hp De La Vergne. This engine was built in 1897 or 98 and is believed to have been in installed in a pumping station in Western PA at that time. The engine was purchased by Buckeye Pipeline and installed in a pumping station at Trail Run, OH in 1917 and was used to pump oil to the refinery at Sistersville WV. It was retired by Buckeye in 1952, then run one more time in 1955 to flush the lines. John Wilcox bought the engine in 1959 and ran it as a hobby in it's Trail Run location until the late 1970's. The shipping weight of the engine was advertised at 16500 lbs. Thanks to Mike Murphy's help, it only took two days to get it out of the Trail Run building and home. Here are a few pictures of it heading to it's new home in Newark, OH. Will add more photos as the project moves ahead.
ID:	66776   Click image for larger version
ID:	66777   Click image for larger version
Name:	De La Vergne 042.jpg
ID:	66779   Click image for larger version
Name:	De La Vergne 030.jpg
The Following 59 Users Say Thank You to BuckeyeMan For This Post:
Old 11-11-2009, 11:49:20 AM
65vette396 65vette396 is offline
Default Re: De La Vergne project
I want it, you lucky dog. hahaahaha
The Following User Says Thank You to 65vette396 For This Post:
Old 11-12-2009, 12:05:27 PM
Sorry but this one is staying right where it's at. There are only 6 of this type know of, and this one is in real good shape. I'll keep posting photos as I get things done.
For the most part it will be mostly cosmetic, the hardest part is trying to make new paint look old, and thats going preaty good, its just a lot of work.... here are a few more photos.
Name:	De La Vergne 007.jpg
ID:	66955   Click image for larger version
Name:	De La Vergne 034.jpg
ID:	66956   Click image for larger version
Name:	De La Vergne 010.jpg
ID:	66957   Click image for larger version
Name:	De La Vergne 019.jpg
The Following 7 Users Say Thank You to BuckeyeMan For This Post:
Old 11-12-2009, 04:24:08 PM
And I don't blame you for that at all. Super neat piece. Good luck with the restoration and please do keep us informed. Drew
Old 11-14-2009, 08:39:54 PM
I guess I should have started with these pictures. The first is the pumphouse where the engines were housed. The building has unique structure in that the pump room and engine room were seperated. In the center of the building you can see some louvers that was an air space between the two rooms; in case of a pipe breakage the fumes would not get into the engine room. Picture two shows the engine before I started to dismantle it. As you can see there were a lot of parts and pipes removed. Photo three shows a 10-1/2 HP Rushton-Hornsby that was also in the engine room. This engine was mainly responsible for running the line shafting in the pump room. It's job was to run a water pump which can be seen in the background, a small air compresser and a double acting National Transit suction pump. This engine was removed by me two years ago and reburbished. The last photo shows the National Transit triplex pump that pumped the oil to the Sistersville, WV refinery.
ID:	67116   Click image for larger version
ID:	67117   Click image for larger version
ID:	67118   Click image for larger version
Old 11-14-2009, 09:01:03 PM
Here is a photo of the Ruston after I spent the winter 07 & 08 cleaning it up, It is also an oil engine. Both engines had to be taken completely apart and cleaned due to a flood in Sep.of 95, there was over 4 feet of water in the engine room. Thanks to John Burns, Doug Thornhill and Linda (my wife) for the help in removing the Ruston...
ID:	67120   Click image for larger version
Old 11-16-2009, 01:57:31 PM
m_thompson m_thompson is offline
Yours looks very similar to the one at the NEWSM. it is the same vintage and was also used to run a pump.
The manual says a man and a small boy can start the engine. It was a little more difficult than that.
De La Vergne Oil Engine at the NEWSM
Old 11-16-2009, 04:08:33 PM
FArmstrong FArmstrong is offline
What's the status of the National Transit triplex pump?
Fred
Old 11-17-2009, 03:20:16 AM
Right now the pump is still in the building, but it will soon be removed as well and set back with the engine. Its in real good shape, and I have some NOS parts for it that will be going on as well....
Old 11-18-2009, 03:24:49 PM
After spending two weeks on the tlr. so the engine could be cleaned of all the old oil and grease, and mud and any chipping paint be removed, to do this I used about 10 cans of ovencleaner and a steam cleaner, this works real good for removing almost everything including about 95% of the old paint from the flywheels,(witch was coming off anyway).
I used Dupont Industrial coating on all the bair cast iron parts. Then came the fun part getting engine back off the tlr. and moved into it's finel resting spot...
I got the flywheels repainted right a way, and by using the Dupont primer this made it real easy to give it the look of being old paint.(put a lot on and then before it dryes wip it back off in the spots where it would normaly be off) and because hard to find a flat paint,I went over the wheels with a scotch bright pad to take the shine off....
ID:	67395   Click image for larger version
ID:	67396   Click image for larger version
ID:	67397   Click image for larger version
Name:	Fairbanks +++++ 001.jpg
The Following 10 Users Say Thank You to BuckeyeMan For This Post:
Old 11-18-2009, 03:39:46 PM
Tom Winland's Avatar
Tom Winland Tom Winland is offline
Banner Sponsor
Images: 8
Lookin good Dave. Are you going to have it up and running for your get together next year?
Tom Winland
Ohio
http://gasenginetom.com
CHECK OUT MY ENGINE VIDEOS AT
http://www.youtube.com/user/gasenginetom
Old 11-18-2009, 05:07:58 PM
Tom, O yes, if the weather holds out the way it been so far, I'll have up and running very soon, I'v also been spending a lot of time on the twin Kline, trying to get the crank rubed in..
Old 11-18-2009, 05:46:59 PM
Banner Sponsor
Images: 8
Looks like you have the De La Vergne sittin beside the Kline. Those two will look really nice sittin beside each other. Hopefully I'll be able to make your get together this coming year.
Tom Winland
Ohio
Old 11-20-2009, 11:54:55 AM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
Here are a few shots of the engines in the station.
ID:	67463   Click image for larger version
The Following 11 Users Say Thank You to Chris Austin For This Post:
Old 11-20-2009, 12:58:06 PM
Thanks Criss, those are better photos then I have. I'v got some old one before I got this new camera, but I have no way of scaning them. Thanks again
Old 11-20-2009, 10:32:30 PM
Bob Geyer Bob Geyer is offline
Smile Re: De La Vergne project
BuckeyeMan,
Great pictures and great engine. Congratulations on that one.
Wouldn't happen to know who has the other five would you?
Bob
Old 11-21-2009, 07:36:59 PM
Got a little more work done this week, Governor apart and cleaned up, spent about 6 hours on the conecting rod cleaning and trying file the pipe wrinch marks out, being in the oilfield they are rough on things, and the huge name plate cleaned and ready to go on. The rod hooked to the crank ,that went well also.
ID:	67575   Click image for larger version
ID:	67576   Click image for larger version
ID:	67577   Click image for larger version
The Following 5 Users Say Thank You to BuckeyeMan For This Post:
Old 11-21-2009, 08:37:15 PM
Here are a few more photos and a small walk around video, I also spent another 6 hours or so on the side shaft (that good old pipe wrench). A lot of the parts have just been stuck on, but on Friday night we started tighten things up in place.. Also got some paint on the rest of the places that where bare cast iron and trying to blend it in with the old it was quit a job... Thanks everyone for looking and thanks to Harry for providing a place to post this...
http://www.youtube.com/watch?v=SlafYPhm5nQ
ID:	67581   Click image for larger version
ID:	67582   Click image for larger version
The Following 11 Users Say Thank You to BuckeyeMan For This Post:
Old 11-23-2009, 01:34:44 AM
BuckeyeMan,
Here you go gentlemen, this was done with the help of Greg Johnson in Southern California, Ed Vanke in Oregon, Dave Hawkins in Ohio and Ray Hooley in the U.K. Thanks to all of them. If anyone knows of more, please let me know and I'll add them to the data base.
1. Smithsonian
4 HP # 1501
2. Ed Vanke
Carlton Oregon
9 HP # 1519
3. Bob Geyer
Le Grand Califonia
9.5 HP # 2782
4. Rollage
( Jim and Keven Withers )
125 HP #2989
15 or 20 HP # ( Unavailable )
5. Dave Hawkins
35 HP # 3121
6. Coolsprings Power Museum
35 HP # 3318
7. New England Museum of Wireless and Steam
25 HP # 3355
8. Rough and Tumble
( Mike Murphy )
50 HP # 3558 ( formerly owned by Nate Lillibridge )
9. State Park Louisiana
HP and number ( unavailable ) condition poor
10.West Virginia
35 HP # 2921 ( SCRAPPED )
Bob
Old 11-23-2009, 12:27:29 PM
Tilton Marter Tilton Marter is offline
bob, what state park in louisiana is the engine in. i live in miss. and my home town is bastorp, la.
3 1/2 HP 1894 De La Vergne Akroyd Project Fred Prichard Antique Gas Engine Discussion 22 08-29-2015 05:43:57 AM
35Hp De La Vergne up and Running BuckeyeMan Antique Gas Engine Discussion 1 01-24-2010 11:04:13 PM
De La Vergne Restoration Project Mike Lucius Antique Gas Engine Discussion 1 12-14-2009 03:00:37 AM
De La Vergne Restoration Project Mike Lucius Smokstak Down Under 1 12-07-2009 04:08:58 AM
200 HP De La Vergne Dustin D Ehli Antique Gas Engine Discussion 6 01-31-2007 08:10:30 PM
