Oil Field Engines
739 Fairbanks Questions
this thread has 52 replies and has been viewed 5590 times
Old 02-15-2010, 10:14:48 PM
Pete Nichols Pete Nichols is offline
Default 739 Fairbanks Questions
First I want to thank Chad for selling the engine to me .
Now for the ?'s :
Would this engine date with the standard Fairbanks serial # list ?
( the serial # is K 521699 )
Engine has brass Fairbanks Morse tag, then it has another small brass tag below it . This tag has the following info. on it : serial # 169 date 8-70 and bore 9.250 .
Is the small tag a rebuilders tag or something else ?
If I would buy a book for this engine would it show how to plumb engine for propane gas ?
Thanks for any help. I'm sure there will be more ?'s .
Thanks, Pete
Old 02-17-2010, 10:45:04 AM
Doug Waggonner's Avatar
Default Re: 739 Fairbanks ?'s
My 739 has a date cast into the cylinder casting. Your # of 521699 dates to 1922 Which is not correct. The K could stand for Kansas City
The smaller tag with the 8-70 date sounds like a rebuilders tag.
The ZC series of engines werent around before 1928, and I'm almost 100% sure that the ZC 739's didnt come into production untill after WWII
The parts book is available on line at www.arrowengine.com or give us a call and we will send you a copy of it.
If your engine has the origional carb on it, then your set for running on propane. There is a 3/4" NPT fitting on the side of the carb between the butterfly and the gasoline resivoir.
The Following User Says Thank You to Doug Waggonner For This Post:
Old 02-18-2010, 08:44:04 AM
Chad's Avatar
Chad Chad is offline
Mr. Pete,
want you please post some good pictures of the engine now sense all parts will be able to be seen..
it was a great pleasure to be able to meet you and your friend.
I hope there will times in the future that we will be able to get together again.
get the ole girl running and enjoy her for me...as i know you will.
Chad
The Following User Says Thank You to Chad For This Post:
Old 02-21-2010, 02:30:34 PM
Allan Wright Allan Wright is offline
Default Re: 739 Fairbanks Questions
Pete, I did a little digging this morning and came up with some information. The 346, 503 and 739 came out in 1944. This information came from one of C.H. Wendel's books. I have a 1943-1944 Composite Oil Field book and it lists these engines in it.
Fairbanks moved their ZC line of operations from Beloit to Kansas City in 1953. So from that I would say your engine was made after this move in 1953.
Good luck with your engine and like Chad said, where's the pictures? Get the camera out Dude, we need to see.
The Following User Says Thank You to Allan Wright For This Post:
Old 02-21-2010, 09:45:02 PM
I got to mess with engine some today , Found some casting tags :
crankcase has 12-20-57 D
crankcase cover has 1-7-58 D
flywheels has 1-31-58 D
water hopper has 2-6-58 D
Looks like engine might be late '58 or early '59 .
I also noticed that all the part #'s have a KC just below them.
Also noticed the small tag that might be a rebuilders tag has GRAYCO along with serial# 169 date 8-70 bore 9.250 .
In my first post I had serial # as K 512699, but the serial # is K 521966.
I'm going to have to take the head off to get valves unstuck and clean the mice nest out !!!!!
Took the carb. apart to clean it out .( found a float and needle valve in the square part of body )
Is the carb. on these engine designed to start on gasoline and switch to propane?
After buying the engine don't have any money left for a camera !!!!!
Thanks for the help so far !!!!!!
Pete
Old 02-22-2010, 02:49:35 AM
Yes, the factory carbs were set up so the operator could start them on gasoline then switch over to natural gas / propane. Do you see the 3/4" NPT threaded hole in the side of the carb? That is where you will plumb in your propane. Most charcoal/BBQ propanke regulators will work fine if your just wanting to run the engine as a display /no heavy load. The secret to making it run smooth as a clock is to use a real dial cock at the carb and the choke plate that goes inbetween the carb and air cleaner.
Once you switch it over from gasoline to propane, start choking off the air, and dialing down the propane with the dial cock. With a little fine tuning there you'll have that 739 running like a dream! You'll be surprised just how little propane it takes to make em run really slow.
Keep us posted on your progress!
Old 02-22-2010, 06:50:59 AM
Doug,
The carb, has a 1" npt hole for the propane. but there is no choke plate between carb. and air filter .
Pete
Old 02-22-2010, 11:09:04 AM
The part is # D-202-346 for the choke plate / air damper. The ZC346, ZC503 and ZC739 all use the same one. Arrow does not carry that one any more but you should not have any trouble finding a used one.
Old 02-22-2010, 02:36:23 PM
Reed Engine's Avatar
Ah, but Arrow still carries the 202-118 and it's the exact same thing. Grasshopper.
Old 02-22-2010, 02:44:38 PM
It is? I thought the D202 had larger bolt spacing? But I have been wrong once before......
But if Reed says its the same then, it's the same
Ok Pete, then thats what you need!
Questions on Fairbanks Morse Shine Stringer Antique Gas Engine Discussion 10 10-03-2007 02:38:16 AM
fairbanks za questions earniemanson Antique Gas Engine Discussion 3 10-12-2006 01:05:14 PM
Fairbanks T Questions Larry K Antique Gas Engine Discussion 17 04-08-2005 10:58:34 PM
Fairbanks questions Darryl Boyd Antique Engine Archives 0 09-21-2002 05:22:06 PM
More Fairbanks H questions scott Antique Engine Archives 8 01-07-2001 06:41:05 PM
