Oil Field Engines
Another Reid
this thread has 72 replies and has been viewed 18361 times
Old 04-07-2016, 08:13:49 PM
Skidmore's Avatar
Skidmore Skidmore is offline
Photo Re: Another Reid
Got the cylinder cleaned up today. Heated up the copper sealing rings to soften them up then installed the valves. Had to heat and drill out a few studs that broke off. Ran a tap in all the holes then new studs. It's going my way now.
Name:	Reid copper  valve sealing rings.png
ID:	250998   Click image for larger version
Name:	12 hp transfer valve.png
ID:	250999   Click image for larger version
Name:	12hp Valve area.png
Skidmore aka engine hoarder
The Following 3 Users Say Thank You to Skidmore For This Post:
Old 04-09-2016, 08:17:08 PM
Skidmore's Avatar
Default Re: Another Reid
Today cut out new gaskets and installed all the clean out covers . This one has the long ugly 10 bolt top cover. Put the pistons in the cylinder and then bolted it to the bedplate. Water and Gas plumbing is next .
Name:	cleanout cover gasket.png
ID:	251098   Click image for larger version
Name:	12hp 10 bolt top plate.png
ID:	251099   Click image for larger version
Name:	10 bolt top plate.png
The Following 2 Users Say Thank You to Skidmore For This Post:
  #63
Old 04-11-2016, 10:25:32 PM
Skidmore's Avatar
It's all back together and running , compression was a little low but the more it runs the better it gets. Need to clean it up and find me a Brass nameplate. Check out my homemade Reid chimney.
Name:	Chimney Homemade.jpg
ID:	251345   Click image for larger version
Name:	Homemade chimney.png
ID:	251346   Click image for larger version
Name:	12 hp running.png
  #64
Old 04-11-2016, 10:42:34 PM
JWithers JWithers is offline
I like the choke tube you made for it. After we get our 15 started we thread in a reducing bushing down to 1 inch. I may have to explore your idea.
Jeremy Withers
The Following 2 Users Say Thank You to JWithers For This Post:
  #65
Old 04-11-2016, 11:16:29 PM
Skidmore's Avatar
You can really dial a Reid in with the two adjustments. Shut the air off with the chock and start turning the acetylene gauge down to 5 or below. Puts the engine under a load and helps with misfiring also make the propane bottle last longer at the shows
Name:	Air choke.png
ID:	251353   Click image for larger version
Name:	acy guage.png
  #66
Old 04-12-2016, 08:12:47 AM
David A. David A. is offline
just got my reid 15 hp, home, I need a pic of the oiler tree on main brgs, mine is missing the tree and related oiler and wiper, or brush, I have the part on the con rod. I am guessing that the orig color on reid's are red?, Mine has red paint( old), and green flywheel faces, will post pic this evening, thanks a lot, any info would be great, thanks dave in ark
The Following 4 Users Say Thank You to David A. For This Post:
  #67
Old 04-12-2016, 09:30:53 PM
Skidmore's Avatar
David A here is a Picture of my Sons 15 hp Script Reid. It's painted with PPG Lacquer. Dark Carmine it was used on 1976 GM trucks. He wanted all the Bells & whistles on his engine. Check out the oiler tree.
Name:	dill dog reid 007.jpg
ID:	251389   Click image for larger version
Name:	dill dog reid 008.jpg
  #68
Old 04-13-2016, 07:26:54 AM
thank you mr. skidmore, that will get me in right direction
The Following User Says Thank You to David A. For This Post:
  #69
Old 04-22-2016, 08:56:33 AM
Peter Holmander Peter Holmander is offline
I have followed this thread from the beginning and I noticed that on all your Reid engines, you remove all the clean out covers. I'm assuming that it is to make sure they are as clean as possible so cooling water will flow properly and also to check for any freeze damage. Is there any other reason? I've never had them off my 15 and was wondering if maybe I should do mine.
Old 04-22-2016, 08:33:19 PM
Skidmore's Avatar
Peter, We always pull the covers off and pressure wash out the acorns, mice nest and mud. A lot of times a cover is cracked or a broken stud and then you got water leaking. Like any rebuild you got to replace all the gaskets.
The Following User Says Thank You to Skidmore For This Post:
  #71
Old 02-21-2018, 09:09:44 PM
Skidmore's Avatar
Can anyone tell me if Wico Oc Mags were built in both Right and Left hand configurations. They are correct side up on right hand Reid engine but upside down on the Left hand. Check out the photo
Left hand dial is upside down Right hand dial on top easy to access
Name:	#1997  12hp Reid.jpg
ID:	303673   Click image for larger version
Name:	12hh  Wico_LI.jpg
Old 02-24-2018, 03:40:26 PM
On the OC, you should be able to remove the lead out tower and reverse it.
  #73
Old 02-26-2018, 10:25:31 PM
They were made with a crossover shaft that allowed the control to be on the other side via external cogs. Hard to find them though.
Bill Klein
The Following User Says Thank You to W.P.Klein For This Post:
Reid Tag Bob Hanauer Oil Field Engines & Related Equipment 3 04-25-2009 10:22:31 PM
My 30 HP Reid JHFoster Oil Field Engines & Related Equipment 3 10-08-2008 05:02:41 PM
Reid HP ? Tom Winland Oil Field Engines & Related Equipment 3 08-15-2007 08:33:04 AM
Reid Keith Smigle Antique Engine Archives 4 12-15-2002 02:07:34 AM
6 HP Reid Craig Prucha Antique Engine Archives 0 09-11-2002 07:09:21 AM
