Gas-to-Diesel conversion on single-cylinder engine?
this thread has 19 replies and has been viewed 20017 times
Old 04-14-2010, 02:24:05 PM
Oberon67 Oberon67 is offline
Default Gas-to-Diesel conversion on single-cylinder engine?
So... I was wondering if it could possibly be feasible to take an iron-block flathead single-cylinder engine like a Clinton or Kohler, shave the head to raise compression, put a big flywheel on it, put a mechanical fuel injector in the spark plug hole, and have a one-lunger diesel engine.
Just an idle thought, really... but if it's possible, I'd bet someone here has tried it.
-Oberon67
Old 04-14-2010, 04:02:02 PM
Skip Landis Skip Landis is offline
Default Re: Gas-to-Diesel conversion on single-cylinder engine?
GM did it with the 350 cid engine. not a great success.
Old 04-14-2010, 04:24:15 PM
GM did it with the 350 cid engine. not a great success. GM did it with the 350 cid engine. not a great success.
True... but in this particular instance, "...the wonder is not how well the bear dances, but that he dances at all." After seeing the home-brew HVID engine, it seems to me that nothing's impossible for this crowd.
Old 04-14-2010, 06:03:38 PM
John Newman, Jr.'s Avatar
If I were to attempt such a project, I believe I would start with a good stout Wisconsin engine since they are made with lots of heavy cast iron and most have a roller bearing crank. Look for one with the longest stroke possible compared to the bore. Watch your valve to head clearance. You may have to make a custom head to get the compression and clearances you need.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 04-14-2010, 08:43:57 PM
Lead Head
I think a Kohler K series would be a good base, most if not all of them had roller bearing cranks.
Unfortunately I doubt you will ever get the compression you need with a flathead. You would definitely need to machine your own OHV head.
Kohler did have a K361, which was basically a K341 with an OHV Head. It has 9:1 compression (from what I remember, +/- .5 compression points). If I was looking for a small engine to convert to diesel, I would probably start with one of those.
Old 04-14-2010, 09:10:58 PM
An old diesel man told me at least 50 years ago the reason all diesels are overhead valve is, you can not decrease the volume of the combustion chamber enough in an L head engine. You need to remember when rebuilding diesel head 0.015 difference in valve height makes a difference in starting the engine. Also a babbitt bearing will hammer out in short order.
Old 04-15-2010, 09:43:31 AM
I had wondered about that. I was trying to think of ways to reduce combustion chamber volume in the L-heads I'm familiar with, and the best I could come up with was to turn the entire face of the piston into "squish area" (minimum clearance, or essentially zero volume) and relocate the injector over the valves. I still wasn't sure this would be enough, and to judge by what the old diesel man told you, it would not.
I suppose it would be technically possible to build a low-RPM L-head diesel from the ground up, given sufficient stroke, but that's a different animal entirely.
Old 04-15-2010, 11:21:56 AM
vern0n's Avatar
vern0n vern0n is offline
"GM did it with the 350 cid engine. not a great success. GM did it with the 350 cid engine. not a great success."
That is not actually true. There is almost no part that can be swapped from the gas engine to use on the diesel. It is true it was based off the Olds 350, but almost nothing interchanges. The block is differant, the heads are differant, the intake is differant, and the pistons are differant. I don't know if the crank and rods are differant. It just wasn't a very good design.
You could make a diesel out of a Briggs or a compressor, (using overhead valves), but don't expect it to last long.
Old 04-15-2010, 11:38:06 AM
I agree. However, I also think the Kohler with the roller bearings might be a viable option, especially if you were to sleeve it undersized to reduce the thrust against the mains.
It would be a serious undertaking no matter which way you went with it; not something to do with a working motor. As I don't have a machine shop, I won't be having a crack at it in any event.
Old 04-15-2010, 12:35:09 PM
OTTO-Sawyer's Avatar
Originally Posted by vern0n View Post
../There is almost no part that can be swapped from the gas engine to use on the diesel. It is true it was based off the Olds 350, but almost nothing interchanges. The block is differant, the heads are differant, the intake is differant, and the pistons are differant. I don't know if the crank and rods are differant. It just wasn't a very good design...
Actually there were some interchangeable parts. The 350 Olds Diesel block was beefed up quite a bit and made a very strong 'building block' for putting together a high compression, high output 350 or could be bored & stroked a fair amount and still be a good strong block. I don't remember what all was involved in the conversion, but there was an aftermarket company that supplied a kit for converting the Olds diesel back into a gas burner. Pistons, Cam, Intake manifold, Distributor instead of injector pump, and a few other pieces, but overall it wasn't much different than any other rebuild swapping in new parts for old. Of course it was a whole lot cheaper to simply swap in a complete motor from a donor car when the diesels died with a broken crankshaft or other problems, and we did several of those swaps in my Dads Garage putting 350 & 455 Olds motors in pickup trucks, and then a few years later I swapped out a diesel for a 403 Olds in a big Pontiac station wagon for an old family friend in Rockford IL. When I did that swap I was able to hook up just about every sensor, switch, and gage in the wiring harness so he was able to take it to the local garage and plug it in to the diagnostic computer. Pretty impressive to watch a full sized 4 door wagon smoke the tires for a block and a half. And just because I could, I put the diesel valve covers on the 403 gas motor just as a conversation piece. Same valve cover, just a different shade of blue paint. Power steering, alternator, air conditioner, even the exhaust bolted back on with no changes.
As for raising the compression enough in a flat head, I think you can get the compression ratio up high enough with a domed piston going up into the chamber in the head, but the limiting factor would be the airflow, especially if you mill the head and don't carve out larger pockets between the valves and the cylinder.
Old 04-15-2010, 12:47:53 PM
vern0n's Avatar
OK, I'll revise my last statment. There are almost no internal parts that will swap between a diesel and gas Olds 350. Most of the external parts will swap. You can use a diesel block to make a gas engine, but you can't make a gas block work for the diesel, (no provision for the injection pump). How did the Olds 350 end up on the air cooled lawn mower engine site anyway ????
Old 04-15-2010, 01:13:25 PM
Right off the bat on the second post....
As for the injector pump, it was shaft driven off the end of the cam in place of the distributer.
Old 04-15-2010, 04:38:51 PM
vern0n's Avatar
The injection pump was driven off a special cam gear/timing gear. The pump was mounted in the valley just like the 6.2 diesels. The block has a hole above the timing chain for the pump to go through.
Old 04-15-2010, 09:57:53 PM
So now I stand corrected... it's only been 24 years since I worked on one of them
The point is, it can be done, IF a person (or company) wants to invest the time and effort to do so, whether it's practical or not is a whole 'nother story
They converted steam engines in to halfbreed gas engines, Preston Tucker modified an opposed flat six aircooled helicopter engine into water cooled for his 1948 Tucker automobile, Ardin made Hemi heads for the Flathead Ford.... Where there's a will, there's a way !
Have fun with it if you pursue the project.
Old 04-16-2010, 03:31:54 PM
Doug Ourada Doug Ourada is offline
I have a small 5 hp recoil rope start diesel engine. It was made by acme and was on a generator unit. It is about the size of a kohler engine.
Old 04-16-2010, 03:56:53 PM
Would you mind posting a picture?
Old 04-17-2010, 01:31:19 PM
Lead Head
There are actually a couple of motorcycles running around that had the engines converted to diesel, even still retaining the factory aluminum block and heads.
A cast iron kohler K361 with the OHV heads would should be more then capable of supporting the diesel process for an engine that wont see much hard abuse. It would be fine to power something small, or as a display engine.
Old 04-17-2010, 10:25:22 PM
enginenut2 enginenut2 is offline
Valve in block diesels have been built but didn't win out in the long run.
I have pictures of the first Waukesha diesels (before the Hesselman deal) which were L head and the American Monovalve which had 1 valve in the block which served as both inlet and exhaust.There are probably some more but the breathing ability probably proved so obviously inferior that the layout was discarded in favor of the I head.
Old 04-17-2010, 11:42:00 PM
Now that I think of it, there is a diesel powered garden tractor that clunk clunk clunk's its way around the show grounds at Freeport IL every year.
I never looked the engine over close, but it's about the size of an older 12 hp Wisconsin .
Sounds like it's about to blow apart, but it keeps going and going and going like the energizer bunny.
Old 04-18-2010, 08:21:26 PM
I don't have a pic of mine, it's buried on a shelf. The Acme diesel engines were common on the BSC two wheel garden tractors.
Farymann Single Cylinder Diesel 22L0577 JALaswell Vintage Diesel and Oil Engines 1 06-10-2009 09:13:55 PM
Farymann / Briggs Single Cylinder Diesel JALaswell Vintage Diesel and Oil Engines 7 05-08-2009 02:31:42 PM
Single cylinder Homelite Diesel generator ID cummins88 Generators & Electric Motors General Discussion 2 01-09-2009 12:59:22 PM
Fairbanks Morse Model 45 - Single Cylinder Diesel Ted Rozanski Antique Engine Archives 0 07-29-2002 01:11:32 PM
Single Cylinder Diesel Onan Steve Onan Generators 0 10-14-2001 03:46:58 PM
