Oil Field Engines
Need Info on Bessemer Engine... Help!
this thread has 33 replies and has been viewed 3782 times
Old 05-09-2010, 10:21:38 PM
Rod Fielder Rod Fielder is offline
Default Re: Need Info on Bessemer Engine... Help!
hey scott
you going to portland
rod
Old 05-09-2010, 10:47:01 PM
Skidmore's Avatar
Skidmore Skidmore is offline
No, I'd love to go but no money and no time. I would like to go to the August show and take my dad. I've never been there. May need to get some pointers from you on camping, etc.
Old 05-09-2010, 11:11:27 PM
JIMnWV's Avatar
JIMnWV JIMnWV is offline
eMail NOT Working
Thanks Skidmore, That Sounds Great to Me.
Jim
Old 05-14-2010, 07:43:31 AM
JIMnWV's Avatar
eMail NOT Working
Got in from Buffalo, NY this Morning about 1:00am and Daybreak could'nt come soon enough. Got the Head off the Bessemer and measured the bore, it is 9 5/8 inch exactly, so I'm guessing this would be the 20hp Correct?
Thanks again
Jim
Old 05-17-2010, 06:13:08 AM
JIMnWV's Avatar
eMail NOT Working
A couple Pics after Pulling the Head.
ID:	79204   Click image for larger version
ID:	79205   Click image for larger version
The Following User Says Thank You to JIMnWV For This Post:
  #26
Old 05-17-2010, 08:09:10 AM
Skidmore's Avatar
Looks like your ready to pull the piston and the check rings. Is it stuck? One lungers are a little harder to get the piston out , you have to unthread the piston and rod out of the cross head.If the piston is stuck sometime we have to saw the rod into in order to get piston out,then have a new rod made. By the way PB Blaster is on sale at tractor supply good luck
Old 05-17-2010, 06:21:23 PM
JIMnWV's Avatar
eMail NOT Working
Hi Skidmore,
Yea She's Stuck, Piston is almost all the way back so I'm Hoping there is'nt much behind the Piston, Done used 1 can of P.B Blaster and tractor Supply is just down the Street from the Motel here in Hamburg, NY (Buffalo). I Think the worst part is the cylinder oiler is gone and water has traveled down on the piston and took some dirt with it, I may have Met My match but I'm gonna do My best to Bring Her back so Keep Me in Mind if You Run across some 70 inch Flywheels for 20hp.
Jim
Old 05-17-2010, 06:34:51 PM
50% tranny fluid and 50% acetone. can't get any better. i still can't figure out the cylinder bolts to bed plate on a 20 h.p. if your carefull, you can put a block of wood against the slide and use a porta power or bottle jack to push the piston forward, but don't use much pressure. use a little pressure and then a 2 lb. hammer with block of wood on the slide. just be gentle. if it doesn't move, put more lube in cylinder and wait another day or so. you can use a 4" x 4" on the piston head, but use a small hammer with light strokes. the vibration will help, but don't knock a hole in the top of the piston.
The Following User Says Thank You to Rod Fielder For This Post:
  #29
Old 05-17-2010, 10:23:26 PM
Skidmore's Avatar
I would remove the rod packing flang and the cross head bars, also the main connecting rod. That way your only friction is the piston and rings in the cylinder. All those parts are stuck or stiff and it would take alot of pressure to move everything. Before long you will have every part of this engine apart. Just my two cents. I'm not a pro - still learning myself. Hope this helps, skidmore
The Following User Says Thank You to Skidmore For This Post:
  #30
Old 05-17-2010, 10:50:01 PM
JIMnWV's Avatar
eMail NOT Working
Thanks Skidmore,
I have actually Headed in that very direction, got the packing flange out, and the guide plates are off on top, and You are Correct, more than just the Piston was Stuck.....but I See advancements Each Day. Trying to Find a Man up here close to where I'm Working that They Say has lot's of Engines Including a Snow Engine, Just like to Look at His Treasures and take some Pics, Hopefully Our Paths will Cross.
Jim
  #31
Old 05-19-2010, 05:44:27 PM
JIMnWV's Avatar
eMail NOT Working
WOO HOO....The Piston is out safe and sound, and nothing is Broke as of yet. What is the next step of Advice? Anyone Know where I might find a Hone big enough for this thing? or better yet what do Ya'll do in this case?
Jim
Name:	Bessemer 20hp Engine 008.JPG
ID:	79386   Click image for larger version
Name:	Bessemer 20hp Engine 007.JPG
ID:	79387   Click image for larger version
Name:	Bessemer 20hp Engine 012.JPG
ID:	79388   Click image for larger version
Name:	Bessemer 20hp Engine 015.JPG
  #32
Old 05-19-2010, 05:47:36 PM
JIMnWV's Avatar
eMail NOT Working
A Couple more Pics...
Name:	Bessemer 20hp Engine 016.JPG
ID:	79390   Click image for larger version
Name:	Bessemer 20hp Engine 017.JPG
ID:	79391   Click image for larger version
Name:	Bessemer 20hp Engine 009.JPG
ID:	79392   Click image for larger version
Name:	Bessemer 20hp Engine 013.JPG
  #33
Old 05-19-2010, 10:47:50 PM
Skidmore's Avatar
Looks like your are moving right along.Is the cylinder wall pitted very deep? I made a hone for the 10'' bore , I'll post a picture of it later. We always steam clean the water jackets out ,lots of mineral deposits ,rust ,mice nest and nuts. Tap and die every thread, remove rings and wire brush all rust and carbon off piston, polish piston rod so you get a good seal with the packing. Hope your babbit is good on the cross head thats a real pain to pour. Well keep up the good work
skidmore
  #34
Old 05-21-2010, 07:27:39 AM
JIMnWV's Avatar
eMail NOT Working
Thanks Skidmore,
Hope to Tinker with it a little this Weekend, Gotta Weld up a Farm gate for a Friend or I'd be on it now. I'm really Excited to have the Piston out, and what I See inside does'nt bother Me a bit. I have a pressure washer with 11hp Honda, Hopefully with a Little Simplegreen it will Clean up Good so I can Address the Cylinder.Do You by any chance Know the Landowner with the Flywheels Secured to the Ground by a Tree in case of Hi Winds?
Jim
Info on Cooper-Bessemer engine Bob Zick Antique Marine Engines and Outboard Motors 5 12-10-2008 01:41:25 PM
Info On Bessemer dieselfreakcjw Oil Field Engines & Related Equipment 0 04-28-2006 06:56:19 PM
source for printed info. Bessemer engine Charlie Mc Antique Gas Engine Discussion 0 03-31-2005 09:30:07 AM
Big Bessemer Engine info Gary Bahre Antique Engine Archives 1 11-16-2003 01:46:14 AM
need info: Bessemer chan mason Antique Engine Archives 0 11-11-1999 11:04:18 PM
