Oil Field Engines
90Hp Twin Klein Model B Some Assembly Required
this thread has 81 replies and has been viewed 29664 times
Old 04-10-2011, 03:04:34 PM
BuckeyeMan BuckeyeMan is offline
Default Re: 90Hp Twin Klein Model B Some Assembly Required
False Alarm, Machinery break down...Tim said maybe next weekend. We'll keep you informed....DH
The Following User Says Thank You to BuckeyeMan For This Post:
Old 04-24-2011, 01:55:34 AM
Talking Re: 90Hp Twin Klein Model B Some Assembly Required
Saturday I made a trip up to Sharon Pa.to Tim's shop to watch the first pass through the BIG cylinder... Running the bar at 9rpm's and feeding the bar at .025 per. one rev. it only took a little over 4 hours to make the cut....
Tim's 1951 G.A. Gray made in Cincinnati, Oh. is used all the time for many jobs but this was the first time doing a job like this. They will make one more pass on Monday like the one that was made on Sat. and then a finish cut, that will take maybe 12 or 14 hours, then off to be honed......DH
ID:	105197   Click image for larger version
ID:	105198   Click image for larger version
ID:	105199   Click image for larger version
Old 06-09-2011, 01:14:19 AM
Well I finely got the 2nd cylinder back home. The men up at New Era Machine did a great job, and Tim found a place to get the cylinder honed after he was done boring it. I have it back 2 weeks now and got all the old paint and dirt cleaned and started Priming. It looks like I'm not going to get the piston back till mid July, Its at a nother shop in York Pa. having a sleeve put on. So things are starting to move along again.
Not sure how much work I'll get done on it this summer, I'v got 2 other projects I'm on right now and have one big job coming in sometime later on this summer (50hp) 7 1/2 foot 8 spoke flywheels. We will have some photos of it when we start on it........DH
ID:	108324   Click image for larger version
ID:	108325   Click image for larger version
ID:	108326   Click image for larger version
Old 07-01-2011, 01:51:09 AM
This is the other engine I'v been working on sense I got home from Coolsprings, I just set the 2nd cylinder on yesterday morningl, and got it sanded off for the last coat of paint, I'll do it in the morning. I'v got a few more parts cleaned up and also painted and ready to go on as well.....Still no piston yet. Keith said maybe by Aug. And I'v been working on one other project that I have not started posting on here yet, It will be over on the regular gas engine page.....stay tuned..........DH
Name:	more Klein 011.jpg
ID:	109757   Click image for larger version
Name:	more Klein 014.jpg
ID:	109758   Click image for larger version
Name:	more Klein 021.jpg
ID:	109759   Click image for larger version
Name:	more Klein 026.jpg
The Following 9 Users Say Thank You to BuckeyeMan For This Post:
  #25
Old 04-27-2012, 01:23:44 AM
I am planing on getting back on this project soon. I got the rings ordered a few weeks ago, and told the guy no big rush but I would like them by the middle of June. Stay toned................DH
The Following 4 Users Say Thank You to BuckeyeMan For This Post:
  #26
Old 04-27-2012, 12:06:06 PM
BuckeyeMan,
What a NEAT project! I think that those clamp on counter weights are very interesting. Was there a reason why they did it that way such as maybe making it eaiser to machine? I also like the "steam engine" like connecting rod with the wedges..........
Jeff
The Following User Says Thank You to Jeff Smith For This Post:
  #27
Old 04-27-2012, 01:13:43 PM
Dustin D Ehli Dustin D Ehli is offline
Images: 15
Most high end engines have bolt on counterweights, My Crossley and my Ruston both have them. easier to machine and also you could have a forged steel crankshaft and just bolt on cast counterweights.
Having a blast preserving the past.
My Youtube Channel
Old 04-27-2012, 02:27:20 PM
Dustin is right Jeff. The crank is steel and the counterweights are cast iron. Every gas engine I have has bolt on weights, and as much as I can remember, I can not right now think of any Gas engine that did not have bolt on weights.
This engine was built in 1906 or 07 and National Transit used this style rod bearings on most of there engine, and pumps. They also used Marine style rods on there engines, and it had nothing to do with the year built witch rod bearing they used.
The Following 2 Users Say Thank You to BuckeyeMan For This Post:
  #29
Old 07-25-2012, 08:48:39 AM
I have been getting some work done on this monster.
The first photo is the back side of the piston, you can clearly see the sleeve that had to be added, and that is or was one thing that held this project up a few years back, and then I just started taking on other projects, like the next one............
The Rings showed up about a week before Coolsprings and have been sitting in the box,
so last week I got them out and sized them for the cylinder. I also had to put new pins in the Piston to hold the rings from spinning, this is a ported engine and the ports are wider then the rings. If the ring gap was to make it around to the port will I do not want to think of that mess...
I got the other head off the shelf and got it ready for paint, I just kept working that night, the next thing I knew it was 3:30 am and I'm thinking its cool out tonight I'll just keep going. So the head got painted, Gasket cut, found the rest of the studs (20) of them and got them cleaned up. Needed to make 9 new ones because they where stretched, the next thing I know the suns coming up. O well, got to get it done somehow and its been to HOT most days.
The head went on the later that day after some sleep.
I'v gotten more parts out of the shed for cleaning today, these are the rocker arms, the L shaped ones are for Exhaust, but this job will slow down again tomorrow as the Cylinder for the 50Hp White & Middleton will be showing up here today and I'm going to try to get it done in the next 8 weeks or so. ...........DH
Name:	Twin Klein 002.jpg
ID:	140450   Click image for larger version
Name:	Twin Klein 007.jpg
ID:	140451   Click image for larger version
Name:	Twin Klein 009.jpg
ID:	140452   Click image for larger version
Name:	Twin Klein 011.jpg
Old 08-14-2012, 01:04:57 AM
Back on the twin this past weekend, and got a few big parts cleaned up, painted and installed. The cam shaft was the next piece that had to go on, before I added other things on the front. Had to get the wife out to help with this one. The shaft it self is 8 1/2 feet long, and its made out of 2inch material, and it needed to be lifted up over 7 feet to clear other parts.
I also got the other connecting rod in, Sorry I did not get any photos of that rigging job. The piston was already in the cylinder, so to get the pin in and through the rod,, the piston had to be rotated 180 degrees and the rod installed upside down and then rotated back the right way after the pin was in. What a job that was. The connecting rod is about 250 or 300 LBS. Still have the crank bearing to get fitted up and installed. You can also see in the background the two sets of rocker arms ready to be installed. ............DH
Name:	Klein 001 001.jpg
ID:	142395   Click image for larger version
Name:	Klein 001 002.jpg
ID:	142396   Click image for larger version
Name:	Klein 001 008.jpg
ID:	142397   Click image for larger version
Name:	Klein 001 010.jpg
Old 08-14-2012, 04:14:18 AM
Tom Weatherford Tom Weatherford is offline
Thumbs up Re: 90Hp Twin Klein Model B Some Assembly Required
And I thought I had big projects. What a great looking engine this is going to be. Keep up the great work. It is always a labor of love.
Tom
The Following User Says Thank You to Tom Weatherford For This Post:
  #32
Old 02-04-2013, 01:24:20 PM
I'v been getting a little work done on the twin Klein, It does not look like much. I got the Cam shaft in time, and all the rockers on and adjusted. I went through both the Ignitors, John had picked up lots of NOS. parts for these back when the engines where removed, so I did replace a few of the parts that had some wear on them.
I'v been making some bolts that where missing for the Intake system, and I am hoping to get those parts on here when it worms up a little this weekend. ..............DH
Name:	Ingeco  Parts 005.jpg
ID:	157092   Click image for larger version
Name:	Ingeco  Parts 015.jpg
ID:	157093   Click image for larger version
Name:	Ingeco  Parts 018.jpg
Old 02-04-2013, 01:28:56 PM
Images: 15
Love the cam and rocker arm setup on this engine. Very cool.
Keep up the work and dont forget the video when this monster comes back to life.
My Youtube Channel
The Following 2 Users Say Thank You to Dustin D Ehli For This Post:
  #34
Old 02-13-2013, 11:50:33 AM
I got the Ignitors, and all the linkage installed the other day, and also got every thing timed right I hope. Timing everything was a little bit of a challenge with out rolling the engine through, sense the flywheels are not on right now, but I can turn it over with a ring I made to put on the end of the crank. So what I did was set one piston in the right spot, then moved the cams till the Ignitor tripped and then tightened the set screw, and then did the same for the other cylinder. Work is going slow, but it's going.
I was also ask the question why I was painting the engine the colors that I'm putting on it. Well it is the way Buckeye Pipeline had it painted, So it's staying the way they had it painted. ..............DH
Name:	klein ignitors 003.jpg
ID:	157918   Click image for larger version
Name:	klein ignitors 007.jpg
ID:	157919   Click image for larger version
Name:	klein ignitors 009.jpg
Old 02-13-2013, 06:44:58 PM
RWellman RWellman is offline
You are getting closer, looks very nice!
Reid
The Following User Says Thank You to RWellman For This Post:
  #36
Old 02-21-2013, 10:07:27 PM
Got some more of the Klein together today, Both intake pipes and the Fuel & Air mixer. It is really starting to look like an engine now, and I'm running out of big pieces, Still need to get the Governor out of the shed and get it apart and cleaned up. Then all the little things will take the longest to do. Air pipes, Water pipes, Oil pipes, Gas (Propane) Pipe. The Flywheels will be the last thing put on, so that they are not in the way of other work. Will post more as I get things done. ..............DH
Name:	Klein intake 001.jpg
ID:	158627   Click image for larger version
Name:	Klein intake 003.jpg
ID:	158628   Click image for larger version
Name:	Klein intake 024.jpg
ID:	158629   Click image for larger version
Name:	Klein intake 017.jpg
Old 02-27-2013, 03:12:58 PM
loggerhogger loggerhogger is offline
I would love to see a video of the first time you start that monster.
The Following 2 Users Say Thank You to loggerhogger For This Post:
  #38
Old 04-05-2013, 12:25:38 PM
Making some progress on the big Klein. Oiling system almost done, and so is the water system. Worm weather starting to come, and so other things will need to be taken care of. If anything else gets done I'll post photos. ................DH
Name:	Klein oiler 001.jpg
ID:	162077   Click image for larger version
Name:	Klein oiler 010.jpg
ID:	162078   Click image for larger version
Name:	Klein oiler 011.jpg
ID:	162079   Click image for larger version
Name:	Klein oiler 013.jpg
Old 04-05-2013, 10:32:00 PM
I hate it when the worms come out when it gets warm out.
  #40
Old 04-06-2013, 09:31:29 PM
Thanks Bill, Wrong button.
Assembly Question Model 92 GLF4 Maytag Engine Collectibles 3 03-09-2010 11:52:30 AM
Avery 5-10 some assembly required Joe P Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 01-10-2010 01:07:58 PM
maytag twin assembly[help] Matt McGivney Maytag Engine Collectibles 1 12-27-2009 03:21:55 AM
Maytag Twin 72 Wico - Spark Plugs required? enginesilo Maytag Engine Collectibles 3 06-07-2008 02:46:22 AM
Complete Fan Assembly-Ideal model V GarryB Antique Gas Engine Discussion 2 05-01-2005 05:37:38 PM
