Oil Field Engines
90Hp Twin Klein Model B Some Assembly Required
this thread has 81 replies and has been viewed 29672 times
Old 12-20-2013, 05:42:30 PM
Thumbs up Re: 90Hp Twin Klein Model B Some Assembly Required
I bet the nuts aren't cheap! Hope you can get the number you need. On restoring my engine club's OPSC, we found the lock nut for the piston rod broken,. Most people we contacted would not sell just one - they wanted us to buy a box full! Looks like you fave a few nice projects!
Old 12-28-2013, 06:41:30 AM
BuckeyeMan BuckeyeMan is offline
Default Re: 90Hp Twin Klein Model B Some Assembly Required
One step closer. I got both Studs done yesterday. I'm glad I only had to do two of them. The new studs where made with 4140 heat treat. The Nuts did not cost much (14.70 each) The place I get all my Fasteners is great, I can buy one or 100 of what ever, and even what I call the Full nut Or old style.
Now on to making new Keys, One is missing and the other is just a little wore out. .................DH
Name:	Klein Bolts 004.jpg
ID:	183173   Click image for larger version
Name:	Klein Bolts 012.jpg
The Following 9 Users Say Thank You to BuckeyeMan For This Post:
  #63
Old 12-31-2013, 09:20:51 PM
I got the two Flywheel Keys done today, But I'm starting to lose my mind Because I'll be dam if I can find my Camera now. I took a few pitchers BUT Anyway I'm another step closer. ...................DH
The Following 2 Users Say Thank You to BuckeyeMan For This Post:
  #64
Old 07-04-2014, 06:18:38 AM
S.Upham's Avatar
S.Upham S.Upham is offline
Any update on this one Dave? Looking forward to seeing it run someday.
Old 07-04-2014, 08:41:58 AM
JSWithers JSWithers is offline
Yes, any updates? It would have been 4th of July weekend 1968 when we went to W.VA to get our Klein and made the stops at John's and Trail Run and saw all the engines. I have been waiting a long time to see this run.
Old 07-14-2014, 05:30:10 PM
There is Nothing new to report. Its waiting on me and I have plenty other things going on right now. ................DH
  #67
Old 07-14-2014, 05:50:02 PM
Am trying to wait patiently.
Old 05-20-2015, 07:56:22 PM
tdmidget tdmidget is online now
This won't help you Buck eye man but for others with a worn or undersize piston get a quote on flamespray with aluminum bronze. It is porous and holds oil and will wear the cylinder walls less. Price might be much better than sleeving the piston. Ths is done in aerospace applications frequently and is a proven process. You do , of course, want an experienced hand at this.
Old 05-21-2015, 05:30:08 AM
Thanks tdmidget, I know all about flame spraying pistons, But as I understand it you can only build up 1/8 of an inch any more then that and it will come off. That is why I sleeved the piston, and it did not cost me a thing to have it sleeved.
As of right now I'm running water lines from the engine. I'v spent the last month putting in an entire drain system through out the building and with all the engine already in place it has been a B_____ Gas line and exhaust piping still to do, and the price of pipe has really gone up, and My Money tree died.
Also working on the Dayton getting ready for the BIG SHOW, So I don't think all get fare with this project in the next month. .....................DH
The Following 5 Users Say Thank You to BuckeyeMan For This Post:
  #70
Old 07-16-2015, 11:47:52 AM
I hit the wrong Button..............Dam
Old 09-26-2015, 11:26:01 AM
Been making lot's of headway over the past 2 months. The large Flywheel bolts are now in. Bolts this size you don't just but in and tighten up. You would never be able to get them tight enough to pull the the hub together. There is about .010 clearance between the wheel and the crank. The bolts where heated to about 550 degree and then put in and tighten as quick as I could with the Air gun, and then left to cool. Once everything was cooled down the Keys where driven in.
All remaining small parts have now been all cleaned and painted and installed.
Monday I got the fuel line measured out and headed to the heard wear store, ( Dame Pipe is getting pricey ). Tuesday all the wiring and switches was done, and the nice little shelf that was made by a friend for the spark Generator and it was installed. and so on and so on. It will be running some time in the next few day. I would like to get a few hour's on it by next weekend. If you would like to come see it run and many more large engine here at my place come and join us next weekend at the Best Little show in Ohio. Admission is bring and engine, all others will be charged 50. bucks
Name:	Mostly Klein 003.jpg
ID:	235414   Click image for larger version
Name:	Mostly Klein 007.jpg
ID:	235415   Click image for larger version
Name:	Mostly Klein 034.jpg
ID:	235417   Click image for larger version
Name:	Mostly Klein 030.jpg
Old 09-26-2015, 11:29:09 AM
Here are a few more Photos.
Photo 2 is the Spark Generator pulley. That's all it was made for
Name:	Mostly Klein 032.jpg
ID:	235419   Click image for larger version
Name:	Mostly Klein 035.jpg
ID:	235420   Click image for larger version
Name:	Mostly Klein 037.jpg
Old 10-03-2015, 09:35:00 PM
Mike Monnier's Avatar
Hoarder
I shot about 4 minutes of video today of this engine running. I will post a link once it finishes uploading to YouTube. It was pretty sweet to experience in person!
The Following 8 Users Say Thank You to Mike Monnier For This Post:
  #74
Old 10-04-2015, 12:21:24 AM
JWithers JWithers is offline
Can't wait!
Jeremy Withers
Old 10-04-2015, 09:16:36 AM
Hoarder
Here is video of the beast in operation:
Old 10-04-2015, 12:14:20 PM
Absolutely beautiful!!! As I have said before this has been a long time coming for me. Thank you! It just goes to show that anything is possible. It seems there have been a lot of "bucket list" things happening for me lately.... Again, thanks. Great job!!!
Old 10-04-2015, 04:48:00 PM
k0zak k0zak is offline
Great to see this thing run after reading this whole thread. Wonderful work all around!
The Following User Says Thank You to k0zak For This Post:
  #78
Old 10-04-2015, 07:06:26 PM
Tom Stockton's Avatar
Tom Stockton Tom Stockton is offline
Member
Great show....the big twin was the star!
And the rain all day prepared me for Coolspring.
Tom Stockton
The Following 2 Users Say Thank You to Tom Stockton For This Post:
  #79
Old 10-04-2015, 08:47:57 PM
Hoarder
Sunshine and Temps in the mid 70s today. Typical Ohio weather.
Old 10-05-2015, 12:02:59 AM
Greg Johnson Greg Johnson is offline
I think John Wilcox is smiling because of your work Dave,
Nice job on a huge project..
The Following 2 Users Say Thank You to Greg Johnson For This Post:
Assembly Question Model 92 GLF4 Maytag Engine Collectibles 3 03-09-2010 11:52:30 AM
Avery 5-10 some assembly required Joe P Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 01-10-2010 01:07:58 PM
maytag twin assembly[help] Matt McGivney Maytag Engine Collectibles 1 12-27-2009 03:21:55 AM
Maytag Twin 72 Wico - Spark Plugs required? enginesilo Maytag Engine Collectibles 3 06-07-2008 02:46:22 AM
Complete Fan Assembly-Ideal model V GarryB Antique Gas Engine Discussion 2 05-01-2005 05:37:38 PM
