New Maytag serial number
this thread has 6 replies and has been viewed 1927 times
Old 08-19-2010, 05:04:26 PM
Dale S Dale S is offline
Default New Maytag serial number
Guys,
Where do I find the serial number on my 72D engine. There is a serial number on the backing plate behind flywheel that reads 24785
Old 08-19-2010, 06:04:52 PM
aircoolengine aircoolengine is offline
Default Re: New Maytag serial number
The serial number is stamped in the outside ring around the flywheel.
Old 08-19-2010, 06:18:21 PM
Mark Shulaw Mark Shulaw is offline
Hi Dale, When you find that number on the outer ring I would expect to see it be in the neighborhood or ball park of 834XXX give or take a few hundred or thousand or so if the flywheel and the ignition plate are original to each other.
The number you found 24785 is a number placed there by Eisemann when they built the ignition plate. Mark
Old 08-20-2010, 06:49:07 AM
Thanks...According to the serial it was a October 1937 model
Old 08-20-2010, 09:31:14 AM
Could you quote the exact number? Looking to see how close it actually is to the estimated number. Thanks, Mark
Old 08-20-2010, 02:59:45 PM
834086 is the serial
Old 08-20-2010, 05:46:35 PM
Wow looks like we had a near bullseye on the number estimate. The exact estimate would have been 834785. Your number 834086 actually dates to Nov not October There is a serial number list out there thats actually one month off on the months. You must have gotten ahold of it. Nice engine, good deal. Mark
Decoding a model number and serial number southernkilowatt Onan Generators 7 01-09-2013 11:02:35 AM
Maytag 72 Odd 3 digit Serial number? speleausmining Maytag Engine Collectibles 2 07-26-2010 01:09:19 AM
Maytag serial number / date? Russell M Maytag Engine Collectibles 2 03-17-2010 01:12:14 AM
Maytag serial number Mike S Maytag Engine Collectibles 7 10-19-2009 10:19:29 AM
Earliest Maytag 92 Serial Number Larry K Maytag Engine Collectibles 0 10-30-2005 06:14:50 PM
