Oil Field Engines
Superior Registry
this thread has 40 replies and has been viewed 5762 times
Old 12-28-2011, 01:35:34 PM
Tim B's Avatar
Tim B Tim B is offline
Default Re: Superior Registry
I'm interested. Good luck
Old 12-28-2011, 03:17:24 PM
Bob Willman Bob Willman is offline
My 25hp Type C is #23930. It is not in the 1930 National Supply catalog but is in the 1939 catalog. Mine has the brass circular check/mixing valve. There is a similar 40hp just north of here that has reed valves instead. The gentleman that used to own it thought it was made in the late 1930's. They both have cast iron enclosed cranks and are splash lubricated.
Bob Willman
WB8NQW
Old 12-29-2011, 12:59:56 AM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
Our 25 HP is SN 12008. You can compare features here:
http://herculesengines.com/Superior%2025HP/
The registry sounds like a great idea.
Keith
Keith Kinney
www.HerculesEngines.com
Old 12-29-2011, 01:27:21 PM
Walt Roys Walt Roys is offline
In Memory OF
Hi JR, I think the first 2 numbers in the ser# only apply to Superior 2 strokes. Sombody please correct me if I am in error.
Walt
Old 12-29-2011, 01:27:58 PM
Mike King Mike King is offline
I would love to see this registry get started also!I will send my # of my 5 hp farm engine and I think I still know where there is a 25 hp.
The Following 2 Users Say Thank You to Mike King For This Post:
Old 12-29-2011, 01:41:39 PM
In Memory OF
Mike , don't weight to long on that 25, the scrappers will beat you to it.
Walt
Old 01-10-2012, 01:23:00 PM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
HI WAYNE. IT SEEMS WE ARE ALL TRYING TO MAKE SOME SINCE OF THE SUPERIOR LINE OF ENGINES. THIS ENGINE IN THE PIC THAT YOU POSTED, HOW IS IT SPEED CONTROLLED? DOES THE GOVERNOR CONTROL THROTTLE LINKAGE? DOES THE GOVERNOR ACTION CONTROL ANYTHING ELSE? SEVERAL OF US HAVE DISCUSSED AND HAVE HEARD OF HIT/ MISS SUPERIORS, BUT I HAVE NOT EVER SEEN ONE, yet. WOULD LIKE TO KNOW HOW YOURS WORKS. THANKS, LEONARD
The Following User Says Thank You to Leonard Fausset For This Post:
Old 01-10-2012, 01:36:45 PM
Wayne A Thackery's Avatar
Wayne A Thackery Wayne A Thackery is offline
Leonard,
The engine is throttle governed with a butterfly just before the intake valve. There is nothing else that is controlled by the governor. It is Serial # 40088. This number is also stamped on each end of the crankshaft with a R L prefix.
Wayne A Thackery
Keizer, Oregon 97303
Old 01-10-2012, 02:00:33 PM
Rod Fielder Rod Fielder is offline
my 20 2 cycle is 14981. a R prefix on the end of crank
Old 01-10-2012, 02:14:55 PM
Rod,
The R L prefix is for right-left, if I didn't make that clear. Is yours crank stamped on both ends?
Wayne A Thackery
New Way Engine Registry Tom Adkins Antique Gas Engine Discussion 28 04-27-2016 07:37:19 AM
United Registry Dick Webber Antique Gas Engine Discussion 14 01-19-2015 02:27:55 PM
Domestic Registry? John Willis Antique Gas Engine Discussion 1 04-21-2011 12:12:32 AM
Myrick Registry up PaulGray Oil Field Engines & Related Equipment 1 02-21-2006 09:01:07 PM
HETTINGER REGISTRY STEVEN SCHALICK Antique Engine Archives 0 07-28-2002 11:02:28 AM
