Jacobsen Four Acre mower engine
this thread has 7 replies and has been viewed 3118 times
Old 08-09-2005, 02:13:09 PM
Manuel Azevedo Manuel Azevedo is offline
Default Jacobsen Four Acre mower engine
I am looking for some info on my jacobsen engine. I want to know what year it was built. I dont have the name plate for it, but I have noticed that all of the jacobsen engines i have seen have a muffler mounted with two bolts but where the muffler is supposed to be on mine there is a threaded hole probably around 1 in. wide that is tapered. also mine has 1/2 in. pipe thread spark plug do these things mean mine is older or newer than the others. thanks
Old 08-09-2005, 05:10:20 PM
Question Re: jacobsen four acre mower engine
2 cycle engine or 4? if 2 cycle, it is an earlier model, in the area of 1926-30. What color is the mower? What color is the engine? read the earlier posts on Jacobsen engines!
Old 08-09-2005, 10:56:07 PM
Default Re: jacobsen four acre mower engine
I dont have the mower and the engine has no signs of paint thinks for the help though
Old 08-09-2005, 11:00:48 PM
and the engine is two cycle but do you know of anybody with a four cycle one that might let loose of it thanks again
Old 08-10-2005, 06:08:16 AM
The 4-Acre engines were 2-stroke. Jacobsen called their mower with the 4-stroke engine a 10-Acre. I have most of a 10-Acre engine (missing the magneto and shroud. A lot of people don't believe that jacobsen ever made a 4-stroke engine.
The 10-Acre operates a lot like a Briggs FH-it has an atmospheric intake valve and an external push rod to operate the exhaust valve.
Old 08-18-2005, 11:42:29 PM
Exclamation Re: jacobsen four acre mower engine
Jacobsen actually made 2 4 stroke engines. One like the Briggs FH (made for approx. 3 years), and one like a B&S FI, with both valves mechanically operated, (1 year of production) The 4 Acre machines were a 30" cut, and could do 4 acres a day! Rough cut of coarse. The 4 cycle Jacobsens were used on trimming (18") mowers, and green cutting mowers, for lawns that needed a fine cut. ! acre a day for the 4 cycle machines is more like it - they definately did not make the power the 2 strokers did, one of the reasons dthey were discontinued. They also had oiling issues, and cost more than a third more to build over the 2 stroke engines.
Old 08-22-2005, 12:26:39 AM
thanks for the info!
Old 06-12-2008, 05:50:12 PM
cwmitchell13 cwmitchell13 is offline
hi; i found a 2stroke, i am told it is 2 1/2 hp. can that be true? where can i find specs? the mod. no. says 22114. what vintage would it be? thanks mitch
Jacobsen 4 Acre Mower Tilinghast Antique Gas Engine Discussion 13 04-19-2010 11:03:26 AM
Jacobsen 4 Acre Mower Mag. Help James Wallace Garden Tractors / Mowers / Scooters 4 02-19-2009 03:44:52 PM
Jacosen 23" and 30" 4 Acre Mower. Tilinghast Antique Gas Engine Discussion 5 02-19-2009 03:36:31 PM
Jacobsen 10-Acre reassembly Leonard Keifer Antique Gas Engine Discussion 1 04-03-2005 10:09:07 AM
Jacobsen 10-acre engine question Leonard Keifer Antique Engine Archives 0 04-29-2004 06:38:27 AM
