IHC M Wico EK Magneto
this thread has 7 replies and has been viewed 1342 times
Old 06-18-2011, 08:08:54 PM
MedicHamilton's Avatar
MedicHamilton MedicHamilton is offline
Default IHC M Wico EK Magneto
ok guys i know this sounds stupid but whats a good way of getting these mags off. without tearing the whole engine apart?? the top bolt is out no problem but there is another bolt coming through from somwhere? maytag through the crankcase or is it a stud?? any help with this would be wonderful but the way parting out this engine.1-1/2hp m sparkplug
Old 06-18-2011, 08:10:32 PM
Chris J's Avatar
Chris J Chris J is offline
Images: 833
Default Re: ihc m wico ek mag
The bottom, if stock should be a stud / pin that slips into the mag's bottom bolt hole so you only have to remove the top bolt and pull straight off to get it off after you unhook the trip stuff.
Atleast this is what ours has.
The Following User Says Thank You to Chris J For This Post:
Old 06-18-2011, 08:11:23 PM
John Rigter John Rigter is offline
I think the other bolt is more a pin it should swivel and come off.
Old 06-18-2011, 08:17:58 PM
well thats what i have hear but that stud sure looks threaded to me.
Old 06-18-2011, 08:36:23 PM
Bud Forrer's Avatar
Bud Forrer Bud Forrer is offline
Images: 12
The lower pin is threaded into the Mag top bolt is all that should be holding it. All you should have to do is remove upper bolt and rotate mag back and forth and pull outward towards flywheel and it should come off. Hope this helps.
Bud Forrer
Old 06-18-2011, 08:52:28 PM
Tim Claremont's Avatar
Tim Claremont Tim Claremont is offline
Images: 14
Originally it was a pin, but after all these years, who knows what may have happened.
Old 06-18-2011, 09:09:26 PM
well someone treaded it but i finally got it out. thanks guys
Old 06-18-2011, 09:20:34 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
it is supposed to be threaded & have a screwdriver slot in it.Anyway that is how all of them I have seen have been. It then just slides into the hole, as stated above.
"So Much Iron & So Little Money"
Wico C Magneto rmotzing Magnetos, Ignition Coils and Spark Plugs 1 08-03-2010 05:42:54 PM
Wico AX Magneto johnz Magnetos, Ignition Coils and Spark Plugs 0 10-21-2008 06:16:37 PM
Wico EK magneto Kelley Hulsey Antique Gas Engine Discussion 6 11-13-2007 08:32:46 PM
IHC LA Wico Magneto Dennis Buswell Antique Engine Archives 0 03-02-2004 12:09:54 PM
Wico B2 magneto Ed Kinch Antique Engine Archives 1 07-29-2002 04:48:16 PM
