Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag 72
this thread has 3 replies and has been viewed 549 times
Old 07-09-2019, 04:41:22 PM
wfb26 wfb26 is offline
Default Maytag 72
HELP i have a Maytag twin 72 and will not run in less i put petrol down the bung on the top of the engine then it runs on that petrol and stopes i have looked at the cheque value in tank its ok i took the two screws out of the shaft through the bung. BUT not sure if they are in right can anyone help please
Old 07-09-2019, 09:46:58 PM
Kevin Weis Kevin Weis is offline
Default Re: Maytag 72
Check your governor in the crankshaft to make sure it's installed right and functioning correctly. Start with getting a copy of the service manual for the twin. They are readily available on eBay. Good luck, Kevin
Old 07-10-2019, 04:36:05 AM
Thank you for that I will have a look
Old 07-23-2019, 03:29:32 PM
The engine intakes thru the crank. The governor acts as a throttle and is spring loaded. At rest, it is wide open, and as speed increases, the governor closes the openning in the crank. if installed wrong, no air can enter the engine.
i would also check the fuel pick up. it has (or is supposed to have) a fine screen in the inlet, as well as a small ball in the pick up tube that acts as a check ball for the fuel. if the check is missing, or the screen is blocked, the engine wont draw fuel. To start the engine, the air control must be closed all the way (acts as a choke)
Maytag Washer Wanted to Display With my 1910 Maytag Car Hemi Joel Antique Washing Machines 3 09-26-2018 10:45:56 AM
For Sale: Antique Maytag 1934 wringer washer with gas Maytag engine Charley K Antique Washing Machines 1 07-24-2018 07:01:02 PM
Early Maytag Wooden Tub Maytag Washer Shelby Babcock Antique Washing Machines 16 12-30-2014 11:13:53 PM
Maytag Quick Action & Maytag Quart Can jamesrmorris1 Maytag Engines and Collectibles 4 08-01-2013 09:40:59 PM
Odd barn find Maytag runs again...Maytag prototype or farmer fix? Mac Leod Hit & Miss Gas Engine Discussion 16 11-19-2008 12:45:49 AM
