Briggs 8 hp oil leak output shaft cover
this thread has 3 replies and has been viewed 301 times
Old 07-16-2019, 09:30:49 PM
DTurner DTurner is offline
Default Briggs 8 hp oil leak output shaft cover
I have a 8 hp Briggs that goes to my billy goat vacuum sweep.
I was hoping for some ideas about where the leak could becoming from the cover area.
I have a big job to remove it from the billy goat frame. The impeller has to come off the crankshaft.
You can hopefully under stand I donít want to tear into this. But Iím sick of cleaning up the oil.
Any tips appreciate
The Following User Says Thank You to DTurner For This Post:
Old 07-16-2019, 10:41:37 PM
Default Re: Briggs 8 hp oil leak output shaft cover
Hello. Is your engine's crankcase vented ? Engines build up pressure in the crankcase from compression leaking past the rings forcing oil to leak out of seals and gaskets and gets worse as the engine wears out.
Old 07-17-2019, 01:53:20 PM
Ttry lifting up on the impellor. if it moves, the bearing in the sump plate is worn and the shaft is wobbling. That in turn allows oil to get past the crankshaft seal. While you are at it - check the sump plate bolts. They tend to loosen with vibration, and the gasket begins to leak. If loose, just dont tighten - replace the gasket!
Old 07-17-2019, 01:56:18 PM
There's a lot of vibration from that hunk of an impeller spinning around. I'd say the sump cover gasket is the suspect. While it's off you might as well replace the crank seal. Both are a cheap fix for you.
Oil Leak Somewhere on Side Cover 8 hp Briggs DTurner Small Air Cooled Gasoline Engines 5 02-02-2018 04:27:32 AM
Lister ST2, looking for a stub output shaft DJP Vintage Diesel and Oil Stationary Engines 0 09-03-2016 07:47:45 PM
Briggs 326437 Leak CorkyK Small Air Cooled Gasoline Engines 6 09-19-2015 06:50:41 PM
briggs 23 output shaft diameter? mschreiber Small Air Cooled Gasoline Engines 5 05-11-2015 01:07:33 PM
Output shaft diameter of small engines? Pete Spaco Small Air Cooled Gasoline Engines 5 04-30-2011 02:22:50 PM
