Briggs 10hp Onan Model, code and type
this thread has 3 replies and has been viewed 277 times
Old 08-06-2019, 11:38:07 AM
dab18351 dab18351 is offline
Question Briggs 10hp Onan Model, code and type
I just purchased this engine for $40 and i am trying to identify the Model number but i can only make out 3 numbers and not sure if there are any before it so i can get the right parts and schematic. I know it is a 1979 and probably a generator engine from Onan. I also purchased for $30 a 1958 9FB all intact. Pics attached of the model number plate. Thanks
Name:	onan engine 2.jpg
ID:	340881   Click image for larger version
Name:	onan engine.jpg
ID:	340882   Click image for larger version
Old 08-06-2019, 12:43:53 PM
John Newman, Jr.'s Avatar
Default Re: Briggs 10hp Onan Model, code and type
Yes. There should be (probably) 4 more numbers ahead of the 3 you show for the Model number. Need to clean and / or rub on it some more.
The Code number shows that it was made May 25, 1979
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 08-06-2019, 10:56:06 PM
I did clean it down and found a very faint number. it must not of been stamped to good but I have a pic which it looks like 220432
Old 08-07-2019, 11:37:59 AM
Using your numbers, I found an IPL on www.briggsandstratton.com
Click on 'Support' and make your way using the numbers 220432-0131
John Newman, Jr.
Saint Louis, MO
Onan 7.5 QD Model NHJKA Code 33 and 36 craigspeer1730 Onan Generators 5 10-03-2018 07:56:35 PM
Onan 7HGJAE type B, error 3 code 15 sdetweil Onan Generators 0 09-03-2013 06:07:16 PM
Briggs model U type G carb. conversion to type GQ Dengine Small Air Cooled Gasoline Engines 2 12-02-2012 09:51:03 AM
Need governer linkage diagram for Briggs Model 251417 10HP RFirm Small Air Cooled Gasoline Engines 5 01-12-2010 09:57:04 AM
model 243000 briggs&stratton 10hp. joebee Generators & Electric Motors General Discussion 0 10-08-2004 09:45:15 PM
