Onan/Fairbanks Morse 2 1/2 hp
this thread has 3 replies and has been viewed 260 times
Old 08-17-2019, 10:46:24 AM
Greg M Greg M is offline
Default Onan/Fairbanks Morse 2 1/2 hp
Neat old engine:
ID:	341613   Click image for larger version
The Following 4 Users Say Thank You to Greg M For This Post:
Old 08-17-2019, 03:59:18 PM
Default Re: Onan/Fairbanks Morse 2 1/2 hp
Nice find. I have a model 1B-7 that pretty much looks like your engine. Is that carburetor factory or has a different one been adapted to work on yours ? Mine is a Zenith updraft with a governor to control engine speed. Yours does not appear to a governor hooked to the carb. To me your carb looks to be of a Briggs & Stratton engine. I like those engines, but have seen very few of them.
---------- Post added at 03:59:18 PM ---------- Previous post was at 03:56:19 PM ----------
I see yours has a kill switch button on the blower housing. Mine has a empty hole, but now after seeing yours, I have a idea what fits in the hole.
The Following User Says Thank You to EvilDr235 For This Post:
Old 08-17-2019, 10:10:12 PM
Thanks for chiming in EvilDr235. I suspect you're correct regarding the carb. It looks more recent and is too close to one of the bolt heads behind it. No governor.
This one turns over smoothly. I'll do an oil change and see if it'll start.
If anyone has information regarding date of manufacture, application, etc. I am, of course, interested.
ID:	341654   Click image for larger version
The Following User Says Thank You to Greg M For This Post:
Old 08-17-2019, 11:40:29 PM
It appears to be a Briggs & Stratton Flo-Jet carb. In the picture the intake manifold appears to have been cut and brazed to a different angle to fit the carb. I don't see a governor shaft sticking out of the block like mine has. Go to the Carburetor, mixers, fuel pumps and fuel delivery section and read the Fairbanks Morse by Onan carb question post for pictures of the proper carb. and some related information.
Fairbanks Morse by Onan OTC-23C Ken Karrow Small Air Cooled Gasoline Engines 8 10-20-2016 07:22:16 PM
Old Fairbanks Morse - Onan W2C cbisson Onan Generators 5 10-07-2012 03:09:06 PM
Onan / Fairbanks Morse 1KW Con-Rod John Runyard Onan Generators 3 12-07-2011 05:03:01 PM
Morse-Fairbanks Onan mke Onan Generators 10 11-26-2005 11:27:24 AM
Onan/Fairbanks-Morse Brad Davison Onan Generators 2 08-26-2004 07:41:10 PM
