Briggs & Stratton model HM
this thread has 15 replies and has been viewed 3201 times
Old 09-21-2010, 07:18:33 PM
gambitace71 gambitace71 is offline
Default Briggs & Stratton model HM
hi,i got a briggs model HM.its parts in a box.from every thing i can tell its the same as a standard model H except it came with an air maze spark arester witch is for marine use.instead of the normal cheese grader air cleaner.and a couple of pipe niples and a union instead of a muffler.i know that M stands for marine but i never new that briggs made a marine model H marine engine.it also has some mounting feet that came with it.i thought those were for washing machine use.the type number is 95369 and it was built in 1937.any help would be appreceated.thanks
Old 09-21-2010, 09:01:56 PM
bart price bart price is offline
Default Re: briggs & stratton model HM
I have one it should have an oil pan on it Bart
Old 09-21-2010, 09:11:26 PM
there is no oil pan with the parts.it just has the standard flat plate that the model H engines had.also my parts pages for the model H and HM dont show any other base.thanks kencould we se some pictures of yours.mine wont be togther for a while.thanks ken
Old 09-21-2010, 09:18:25 PM
The base is in the parts list it looks like a base fof a model m Bart
Old 09-21-2010, 09:44:55 PM
ha,im looking in the parts book and i found the base part number.sometimes checking the weight column helps.its 10 pounds.as it usualy goes there is always somthing missing.now i got to find out what the base looks like and then find one.thanks
Old 09-21-2010, 10:00:01 PM
mschreiber mschreiber is offline
i believe the briggs marine ads i posted some time back mention the hm, maybe with it being in a briggs marine engine lineup??? good luck
Old 09-21-2010, 10:12:52 PM
hi,i have some info that shows the AM as the replacement for the HM.but that is it.no picture,no info that came from briggs.i went throught the info that is here on the stack and i cant find anything.is the proper base the same as the m or is it a deep sump like on the later marine engines.thanks again
Old 09-22-2010, 09:17:41 AM
I can't see it replacing the "a" as they're were built at the same time with the "h" being 1/2hp and the "a" being 1hp. . if you answered emails from me you would have been sent all the info i have on briggs marine. copies of 3 different ads and a briggs marine brochure, send me your address and i'll send out what i have. good luck.
http://www.smokstak.com/forum/attach...9&d=1268012496
Old 09-22-2010, 05:37:16 PM
grega's Avatar
grega grega is offline
They didnt replace the HM with the AM as said in the center of mschreiber's ad Models HM IMT AM AMT ect. also all HMs had a base, not a plate like plain H engines. If your tag says HM either someone replaced the base with a plate or the tag isnt off that engine.
-Greg
"There only origionial once"
Old 09-22-2010, 07:30:43 PM
hi,sorry but i do have some info that shows that the model A was an early replacement for the HM.when i can i will dig it out.it also shows the model ZL as the updated replacment for the model RL.just an example.thanks ken
---------- Post added at 04:30 PM ---------- Previous post was at 04:08 PM ----------
hi again,the gentleman i purchased the HM from had several boxes of briggs parts and in those parts was a model m base.that must be the base for the HM.grega if you have an HM could i please see a picture of it.thanks ken
Old 09-22-2010, 09:16:22 PM
Ken the base only fits the h or y block I have been around Briggs engines for over forty years. I have never seen another base like mine.Some of the other briggs guys have never seen another. PM m
---------- Post added at 08:16 PM ---------- Previous post was at 08:12 PM ----------
kEN PM ME YOUR PHONE # THEN WE CAN TALK
Old 09-23-2010, 06:57:06 PM
please help:dose anybody have a picture of one of these engines.as i stated in my first entry it is parts in a box.pictures would be nice before i restore it.thanks ken
Old 09-24-2010, 03:58:55 AM
John Newman, Jr.'s Avatar
Here is a lever start Model H that I restored several years ago.
The riser feet are home-made.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following 3 Users Say Thank You to John Newman, Jr. For This Post:
Old 09-24-2010, 12:57:14 PM
Default Re: Briggs & Stratton model HM
hi,thanks for the pictures.that is exellent work.
Old 08-19-2019, 04:44:03 AM
lzybull lzybull is offline
i have some hm engines for sale. if interested my email is lzybull@hotmail.com
The Following User Says Thank You to lzybull For This Post:
Old 08-19-2019, 09:09:57 AM
grega's Avatar
izybull, do you have any pictures? If you do have a Briggs Marine engine I would be interested.
-Greg
Briggs and Stratton Model A Nick Stewart Small Air Cooled Gasoline Engines 16 01-16-2012 11:51:57 AM
The Briggs and Stratton Model Y Horse Power at 511 Small Air Cooled Gasoline Engines 6 03-04-2010 01:06:22 AM
Briggs and Stratton model A Travis Small Air Cooled Gasoline Engines 11 02-09-2009 09:13:13 PM
Briggs & Stratton model ZZ jerryows Small Air Cooled Gasoline Engines 2 02-07-2006 11:43:26 PM
Briggs and Stratton Model A Pollack Pete Antique Engine Archives 4 09-14-2003 11:32:28 PM
