Fuel consumption
this thread has 3 replies and has been viewed 2935 times
Old 01-23-2006, 05:08:22 PM
Simple_serf Simple_serf is offline
Thumbs up Fuel consumption
Awhile back, the question was raised about how much gas an onan Jc will use under light loads. Today we ran the 15JC under very little load (less than 1000W). This run was done as a maintenance test run. After running for 1/2 hour, this unit used less than 3 cubic feet. So about 6 cubic feet/ hr under little load. I am unsure what the pressure is at the wellhead, which is where the meter is at. Hope this helps a little.
The Simple serf
Old 01-24-2006, 12:15:51 AM
Jim McIntyre's Avatar
Default Re: Fuel consumption
Let's see here... 6 cu ft/hour. Natural gas is about 1000 BTU/cu ft, so you're telling us the fuel input was 6000 BTU/hr.
Something's not quite right. The 15JC, even with no electrical load is going to need at least 10 times that.
Old 01-24-2006, 12:41:39 AM
This is coming directly off the wellhead.
I do know that there is a regulator before the house. Because it isn't my house, I don't know what the pressure is going to it Because it is a different meter than I am used to, I may have misread it.
either that or the meter is shot.....I'd better look into this a little more
the simple serf
Old 01-25-2006, 01:46:32 AM
Gunny or Billy J. might have some old JB and JC spec sheets in their archives. I used to have Onan catalogs that had cut sheets for each model they made. They provided a wealth of information including fuel consumption charts at 1/4, 1/2, 3/4 & full load. Unfortunately, I purged them from my library at the office after all these models became obsolete. Wish I'd kept one of the catalogs. I have a good relationship with the local Cummins distributor. They still have an old catalog and will let me copy whatever cut sheets I need. If Gunny or Billy doesn't have them readily available (sorry for volunteering you guys), I should be able to get them but it may take some time.
15.0 jc fuel consumption Stephen Girouard Onan Generators 1 02-11-2008 10:22:10 AM
12.5 Fuel Consumption Delta13 Onan Generators 1 08-27-2006 03:48:29 PM
45.0 EM Fuel Consumption Jim Davis Onan Generators 0 01-23-2006 09:41:26 PM
LP fuel consumption for 10CW-3R/1A Dwight Mossman Onan Generators 12 11-02-2005 08:14:30 AM
20 HP-N Fuel consumption Alan James Antique Engine Archives 2 04-12-2004 05:28:59 PM
