Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 396 replies and has been viewed 77439 times
Old 11-18-2013, 11:21:01 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Jacobson Machine Mfg. Co., Warren, Pennsylvania
When were their first engines built and in what year did they stopped building engines. As the owner of a 5hp side shaft Jacobson built engine I was not able to find much discussion on SmokStak about Jacobson engines.
I'm even considering initiating another registry if you guys have pictures and data on your Jacobson to contribute to the project.
The highest serial number I've seen is 16656 so it is not a common engine but not that rare either.
The Following 4 Users Say Thank You to Denis Rouleau For This Post:
Old 11-19-2013, 09:51:58 AM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
Dennis, Do you have any information on when the operation was moved to Titusville? Thanks, Leonard
Old 11-19-2013, 01:01:54 PM
I did not know that Jacobson moved to Titusville.
Denis Rouleau
Old 11-19-2013, 01:33:56 PM
Dave Nielsen Dave Nielsen is offline
I think it was in the late teens early 20's when they moved to Titasville after the factory burned down in Warren. I have a 5hp tank cooled that may have been made in Titasville. It doesn't have a s/n tag and I can't find a spot that looks like it ever had a tag. I don't know if Don Worley goes on the Stak, but he could tell us a lot more about Jacobson. Dave
The Following 2 Users Say Thank You to Dave Nielsen For This Post:
Old 11-19-2013, 05:24:24 PM
Tim B's Avatar
Tim B Tim B is offline
I believe Don Worley does do the Jacobson thing. I always wondered why some either had the short fluted hopper and some taller and some vertical and horizontal governors. Ive seen them both ways and mixed.
Old 11-19-2013, 11:05:53 PM
I found and looked at the Jacobson web site by Don Worley. Mr Worley is probably the most knowledgeable person when it comes to Jacobson engines. Unfortunately I did not find many answers to my questions on his web site. I think that a Jacobson engine registry along with dated magazine ads with teach us a lot about these great engines.
Your help is required for this project. I can't do it alone as I only have one Jacobson engine.
Your can send me your engine pictures and data for the registry at: buzzcoil2@videotron.ca
Thank you!
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
Old 11-19-2013, 06:34:40 PM
Maurice Weiler Maurice Weiler is offline
Don has all the information on Jacobson worley@westpa.net
The Following 2 Users Say Thank You to Maurice Weiler For This Post:
Old 11-19-2013, 06:41:04 PM
Doug Sather Doug Sather is offline
The Titusville engines starter in 1923
The Following User Says Thank You to Doug Sather For This Post:
Old 12-09-2013, 07:59:13 PM
Jim Stigerwalt Jim Stigerwalt is offline
Here is a Maynard you can add.
ID:	181609   Click image for larger version
ID:	181610   Click image for larger version
The Following User Says Thank You to Jim Stigerwalt For This Post:
Old 12-22-2013, 11:13:37 AM
Don Worley Don Worley is offline
Another Bullseye ad.
The Following 2 Users Say Thank You to Don Worley For This Post:
Old 12-22-2013, 12:27:25 PM
Were any Jacobson engines exported to Europe and Australia? No one from there have registered a Jacobson. Here in Canada I have only seen a handful of Jacobson engines and they sport the "MOODY" name tag.
Denis Rouleau
Old 12-22-2013, 04:17:50 PM
I'm sending you an order form for a Bull's Eye engine in case you wanted one for Christmas.
The Following 2 Users Say Thank You to Denis Rouleau For This Post:
Old 12-22-2013, 07:06:56 PM
Denis: I will take a set of engines
Old 12-22-2013, 08:43:46 PM
Living examples of Denis' Jacobson ads
ID:	182645   Click image for larger version
ID:	182646   Click image for larger version
ID:	182651   Click image for larger version
The Following 3 Users Say Thank You to Don Worley For This Post:
Old 01-13-2014, 07:47:52 AM
Automatic engine with dynamo. Note use of water-spray in exhaust and gas regulator shell as a possible accumulator.
Old 01-13-2014, 10:56:39 AM
This is a Todd Engine mfd. in Warren Pa. -only one known. You can tell that it is a Jacobson. 1 1/2 hp. There is a different mixer on this engine. The serial number is a Jacobson number.
The Following User Says Thank You to Don Worley For This Post:
Old 01-13-2014, 12:03:21 PM
Denis; This may be what you are looking for. The Southern Planter July 1,1923.
Jacobson Owners please post your serial numbers!
Old 01-13-2014, 07:34:45 PM
Bob Upham Bob Upham is offline
Don heres some pictures of another jacobson that i know of.
unfortunately its not available [yet]. it has all of its orginal paint covered with thick grease. how rare was this model, its the only one like it ive run across.
ID:	184838   Click image for larger version
ID:	184839   Click image for larger version
The Following 4 Users Say Thank You to Bob Upham For This Post:
Old 01-13-2014, 08:34:24 PM
One with the mag bracket is more uncommon. It does look original down to the starting crank and skids. Should take the square gas tank and can muffler. Too bad you didn't clean off the serial number.
Old 01-13-2014, 09:59:39 PM
Bob, any chance you obtain the serial number off of the name tag? It would be interesting to know when it was built.
Don, was Todd an engine builder or a selling agent?
Denis Rouleau
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
