Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 396 replies and has been viewed 75486 times
Old 12-01-2013, 10:55:45 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
Don, I've noticed various numbers on the Underwriters' tag. Can you explain the significance of these numbers?
Denis Rouleau
Originally Posted by Don Worley View Post
For those of you registering engines, please include the Underwriters tag number if the engine has one. Thanks Don
Old 12-01-2013, 11:01:18 AM
Don Worley Don Worley is offline
I will be posting several photos of
Jacobson engines. The first is my 2 HP on original factory cart.
The Following 2 Users Say Thank You to Don Worley For This Post:
  #53
Old 12-01-2013, 11:09:08 AM
My 2 HP Sturdy Jack pump engine and 2 HP vertical gov.
ID:	180794   Click image for larger version
Old 12-01-2013, 11:18:17 AM
Factory photos.
1st is the air cooled "Mascot" engine
2nd and third are the "automatic" engine
4th is the tandem engine
ID:	180796   Click image for larger version
ID:	180797   Click image for larger version
ID:	180798   Click image for larger version
The Following 3 Users Say Thank You to Don Worley For This Post:
  #55
Old 12-01-2013, 11:21:38 AM
Don, do you have serial numbers to go along with the engines, for the Jacobson registry?
Denis Rouleau
Old 12-01-2013, 11:29:23 AM
Original factory advertising about 1906
1st is heavy governor weight engine for close rpm
2nd is a large cart mounted engine
3rd and 4th are of the factory at the end of WWI 1917
ID:	180800   Click image for larger version
ID:	180801   Click image for larger version
ID:	180802   Click image for larger version
The Following 5 Users Say Thank You to Don Worley For This Post:
  #57
Old 12-01-2013, 11:31:30 AM
I wonder if the 5hp vertical Ruger engine referenced onto the Jacobson Machine Mfg. "Proposal" is still around.
Denis Rouleau
Old 12-01-2013, 11:45:22 AM
I will send serial numbers of 16 of my engines and pictures of some of them to the registry email later.
I am just trying to get used to using the site and sending stuff. Don
---------- Post added at 10:39 AM ---------- Previous post was at 10:35 AM ----------
I have not heard of the "Ruger". I assume that it would be the same as the Wards "Invicible" which there are a couple 2 HP left. Don
---------- Post added at 10:45 AM ---------- Previous post was at 10:39 AM ----------
As with the engine tag the Underwriters tags were sequential. Only the engines with the Underwriters gas tank got the tag. If the engine has only the Underwriters tag I could possibly date the engine if enough Underwriters numbers could be found. Don
The Following User Says Thank You to Don Worley For This Post:
  #59
Old 12-01-2013, 11:53:27 AM
Last post for today. Got stuff to do.
Engine seen at Kinzers last two years.
ID:	180804   Click image for larger version
  #60
Old 12-02-2013, 09:57:21 AM
I have a factory sheet listing the information on the Invincible engine.
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
