Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES)
this thread has 10 replies and has been viewed 3510 times
Old 06-01-2011, 11:44:17 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Default Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES)
Here are pictures I took of my 5hp Jacobson:
http://buzzcoil.brinkster.net/moody/page101.html
Denis Rouleau
Old 06-01-2011, 12:36:38 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Default Re: Jacobson Machine Mfg., Co., Warren, Pennsylvania. (PICTURES).
Hi Denis
Nice find for sure,
We used to have one with the vertical Gov that was retagged Moody out of Quebec if you wanna search your archive for that one.
Jonathan
The Following User Says Thank You to Sad Iron For This Post:
Old 06-02-2011, 04:54:30 AM
LarrapMan's Avatar
LarrapMan LarrapMan is offline
Hey Jonathan,
I think we might be getting one similar in 2 weeks time
So there are vertical and horizontal governors, igniters and websters as well as some have the flared hoppers. A friend over here has the exact opposite of ours (igniter, h-gov and flared hopper) tagged a Bulls Eye. Would I be right in thinking that vertical governor, webster fired recessed hopper would be one of the later ones? And it doesn't matter what features it has it could have anyones tag? Although obviously most of the early ones will be Jacobsons as they didn't have any contracts at that point.
Some guys were hinting in the last thread that the horizontal governors were exclusive to bulls-eyes, not so?
Looks like a nice find Denis, how huge is that crank gear overkill. - Joe
Old 06-02-2011, 06:29:39 AM
On a 5hp there was an extra cost of $12.00 for the built-in magneto and an extra charge of $10.25 for a friction clutch pulley.
Denis Rouleau
The Following User Says Thank You to Denis Rouleau For This Post:
Old 06-02-2011, 10:49:02 AM
Bigjoedo's Avatar
Bigjoedo Bigjoedo is offline
Images: 21
Denis,
Very nice engine!! You found it in that good condition or did you restore the engine? Does it run? Thanks for sharing
Bigjoedo
Old 06-02-2011, 08:28:56 PM
Jonathan Widelo's Avatar
Dennis,
I was told by Don Worley at Coolspring last year when I brought my 3hp to exhibit, that the main differences between Jacobson engines and " Bulls Eye" engines that were made for Montgomery Wards and Company, had the flared hopper, and a fly ball governor that was only available on side shaft. The Jacobson engines could be ordered with either a vertical governor or one on the side shaft. The early Jacobson and “Bulls Eye” engines like mine were igniter with battery and coil, my engine has the optional low tension Elkhardt magneto which is run by the back of the side shaft and uses a three pole switch, which allows you to start the engine on battery and coil and run it on the mag after it starts. The later engines used the Webster mag. Nice Find Dennis It looks like a great engine !! Don also makes repro tags for these engine and a lot of great repro parts too.
Joe,
Did you find your Jacobson in the UK or is it an import ? hope to see some pictures when you get it !
~ Jonathan
The Following User Says Thank You to Jonathan Widelo For This Post:
Old 06-02-2011, 09:23:26 PM
Tim B's Avatar
Tim B Tim B is offline
I think the Bullseye and the Jacobson's hp might of been rated differently also. Nice engine there.
The Following User Says Thank You to Tim B For This Post:
Old 06-03-2011, 07:11:01 AM
LarrapMan's Avatar
Jonathan,
I was confused for a moment I thought you were the other Jonathan (Sad Iron)
I bet you have already seen photo's of it on the ads without knowing it. Its not arrived just yet, we are expecting it before June is out. Its in a container somewhere between here and Canada right now
Old 06-04-2011, 09:34:03 AM
Candy T. Candy T. is offline
Hi All,
This ad for the Jacobson is from the middle teens.
Enjoy!
Candy
The Following User Says Thank You to Candy T. For This Post:
Old 06-04-2011, 09:54:07 AM
Originally Posted by Candy T. View Post
Hi All,
Enjoy!
Candy
Interesting placement of the magneto on this unit!
Denis Rouleau
Old 06-18-2011, 11:15:59 PM
Default Re: Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES)
Here is this 2hp Jacobson side shaft as seen in Coolspring. Looks like a miniature engine. Real neat!
Denis Rouleau
ID:	108894   Click image for larger version
ID:	108895   Click image for larger version
ID:	108896   Click image for larger version
Menges Mills, Pennsylvania show pictures Leonard Keifer Antique Gas Engine Discussion 4 07-19-2010 03:45:16 PM
Frick 22x36 threshing machine pictures JunkmanIH660 Farm + Industrial Antiques and Collectibles 24 12-12-2008 11:21:15 PM
Warren Helms auction LAKnox Live Auctions of Engines, Tractors and Old Iron 10 02-20-2007 06:22:24 PM
Whats this machine in the pictures? paul burris Antique Gas Engine Discussion 12 01-26-2007 12:43:38 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
