Go Back   SmokStak > SmokStak® Antique Engine Community > Hit & Miss Gas Engine Discussion > Hit & Miss Gas Engine Projects
Hit & Miss Gas Engine Projects Nuts and Bolts Tear-down, Restoration and reassembly of old engines with photos. Edited in Gas Engine Discussion and moved here by merit or recommendationn.
Fairbanks Morse Z
this thread has 1 replies and has been viewed 300 times
Old 10-20-2019, 07:24:05 PM
Noyes Noyes is offline
Default Fairbanks Morse Z
I have a barn find Fairbanks engine , I think. It has a 3.5 inch bore and a 5 inch stroke, open crank case throttle governed. I have looked in Wendalls book under Fairbanks and it appears to be a Z model. Fairbanks seemed to list several engines under the Z model number with several variations. The serial number is 374868. The only thing missing seems to be the magneto, what should this engine have for a mag? I normally collect IHC engines and this came with a 3 HP M. See attached photos . Any Help from the fairbanks collectors would be appreciated. Thanks Allan Noyes
ID:	347098   Click image for larger version
ID:	347099   Click image for larger version
ID:	347100   Click image for larger version
Old 10-20-2019, 07:39:23 PM
ScooterBob ScooterBob is offline
Default Re: Fairbanks Morse Z
According to the serial number list found here...
http://www.oldengine.org/members/may...s/fmserial.htm
your engine is a 1919.
Fairbanks morse fm-x TractorDom Magnetos, Ignition Coils and Spark Plugs 0 12-17-2015 02:36:55 AM
Fairbanks Morse RV mag lmcalahan Hit & Miss Gas Engine Discussion 13 01-02-2009 09:29:34 PM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Hit & Miss Gas Engine Discussion 4 09-12-2008 11:03:58 AM
Fairbanks Morse Gen Set Bobby J Generators & Electric Motors General Discussion 0 05-12-2002 01:44:27 PM
Fairbanks-Morse W35-150 Richard Weich Generators & Electric Motors General Discussion 3 04-22-2002 12:08:57 AM
