Economy Oiler Parts
this thread has 4 replies and has been viewed 1301 times
Old 02-07-2013, 10:35:59 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Default Economy Oiler Parts
Hey Guys
This little gem came with Dr. Johns Lambert. It was installed on the dogbone governor.
It's missing the cap and we figure there's supposed to be a wick through the stem.
So my question is does any one have one they would care to share a picture or 2 of so we can get an idea of what it should look like??
Jonathan
ID:	157444   Click image for larger version
ID:	157445   Click image for larger version
Old 02-08-2013, 12:56:03 AM
Default Re: Economy Oiler Parts
That type of oiler typically had a loose wire in the hole. The oiler would be mounted on a shaft and the pin would ride on the shaft. As the pin moved a little air would get by and into the glass reservoir which would let a little oil out. The pin should be slightly smaller than the hole, the smaller the pin the greater the feed. Or it could have had a needle valve in the hole.
Old 02-09-2013, 11:50:58 PM
John Davidson John Davidson is offline
eMail NOT Working
Jonathan; No wick in the tube on the Economy. The missing top is a intricate piece with a sleeve that loose fits over the tube in the base. When running, the oil flys around and a small amount get by the sleeve and down the tube. The top has the name cast in it and would be a difficult part to recast. I have a brass and glass economy and a all brass ball shaped ecomomy. Both have fifferent tops. I have a friend who has the glass and brass economy with a broken glass. Get back to me and I will give you his name. Might make one good one out of the 2 if they are the same size.
The Following 2 Users Say Thank You to John Davidson For This Post:
Old 02-10-2013, 09:48:45 PM
Don Selmer Don Selmer is offline
Sad Iron, I sent you a PM.
The Following User Says Thank You to Don Selmer For This Post:
Old 03-25-2013, 10:17:01 PM
Sad Iron's Avatar
Thanks to John D, Don S and JK we've got another Economy Oiler.
This one is a size bigger and the cap won't fit but atleast now we know what we're looking for.
Anyone happen to have seen one in their travels??
PS Patent Date is in 1893...
J
ID:	161305   Click image for larger version
ID:	161306   Click image for larger version
ID:	161307   Click image for larger version
Looking for Drip Oiler Parts Chris J Hit & Miss Gas Engine Discussion 5 09-19-2014 03:48:32 PM
Economy 1.5 HP Drip Oiler David Jones Hit & Miss Gas Engine Discussion 0 06-19-2011 11:27:56 PM
Help need Manzel oiler parts newway1978 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 09-18-2010 02:48:50 AM
Essex oiler on Economy XK engine Zira Hit & Miss Gas Engine Discussion 9 05-11-2010 08:23:08 PM
auyo oiler parts gearald fielder Antique Engine Archives 1 11-12-2000 09:20:28 PM
