Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Amateur "HAM" Radio
Amateur "HAM" Radio Radio Amateurs, Morse Code, Transmitter Tubes, Vintage Equipment, Antennas
Amateur
Show Us Your Radios!
this thread has 10 replies and has been viewed 833 times
Old 02-26-2019, 12:32:42 PM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Show Us Your Radios!
I'll start off with one of my favorite rigs/stations. Kenwood Hybrid TS-830S, circa 1980 with most of the available goodies you could get for it.
The 830S is a solid state transceiver with hollow state or tube finals. A 12BY7A driving a pair of 6146's. The perfect combination of old school and new school. Knobs, buttons and dials, but no menus!
So, show us what you have, had or want!
ID:	329455   Click image for larger version
ID:	329456   Click image for larger version
ID:	329457   Click image for larger version
https://www.onanparts.com
The Following User Says Thank You to OnanParts For This Post:
Old 02-26-2019, 01:14:32 PM
BTPost's Avatar
BTPost BTPost is offline
Default Re: Show Us Your Radios!
Lots of Radios mostly Kenwood stuff.... and a few Computers mostly Macs....
First Pict is HF Stack...
Second Pict is VHF/UHF Stack
Third Pict is Computer Stack
ID:	329459   Click image for larger version
ID:	329460   Click image for larger version
Bruce in alaska
The Following 4 Users Say Thank You to BTPost For This Post:
Old 02-26-2019, 02:19:31 PM
Ret AF Ret AF is offline
I had an ICOM 802 with an automatic antenna tuner. Also connected was a Pactor modem. I installed it on my 40' Catalina sailboat. The port side back stay was the antenna, 50' in length. I could send and receive e-mail anywhere in the world on 12 volts power. The only thing was I could not transmit with the auto helm engaged as the RF from the antenna would throw the rudder hard to port!!!
Old 02-27-2019, 01:08:31 AM
OnanParts's Avatar
Doubtful anyone would be interested in some nudes....Kenwood nudes that is.
You are? OK, here we go.....
A peek inside the TL-922A Amp. These are from before the HV caps were replaced along with a much better glitch resistor.
ID:	329506   Click image for larger version
ID:	329507   Click image for larger version
ID:	329508   Click image for larger version
Old 02-27-2019, 01:12:27 AM
OnanParts's Avatar
Old and new HV cap bank.
ID:	329518   Click image for larger version
ID:	329519   Click image for larger version
Old 02-27-2019, 01:17:59 AM
OnanParts's Avatar
These are the glitch resistors I went with.
ID:	329525   Click image for larger version
Old 02-27-2019, 01:24:14 AM
OnanParts's Avatar
A look inside the TS-830S.
ID:	329527   Click image for larger version
ID:	329528   Click image for larger version
Old 02-27-2019, 01:29:25 AM
OnanParts's Avatar
A peek under the hood of the AT-230 Antenna Tuner.
ID:	329530   Click image for larger version
ID:	329531   Click image for larger version
Old 02-27-2019, 01:33:11 AM
OnanParts's Avatar
Well, I started out with just one of the Hybrids....then two.. I stopped at three....
ID:	329533   Click image for larger version
Old 06-14-2019, 10:18:05 AM
Eric.S Eric.S is offline
OK i'll add some weight to the page
I have a "few" old(er) ships transceivers, a lot of Sailor(Denmark),
some debeg, furuno, harris, B&W, telefunken, siemens, grc106 rohde&schwarz, kenwood, racall, most of it HF.
And no antennas at the moment
Eric
Name:	app debeg.jpg
ID:	337140   Click image for larger version
Name:	app grc 106.jpg
ID:	337141   Click image for larger version
Name:	app sailor 1000.jpg
ID:	337142   Click image for larger version
Name:	app sailor 1135.jpg
The Following User Says Thank You to Eric.S For This Post:
Old 06-14-2019, 01:33:10 PM
And when the micro processor came in the equipment gets some smaller, sometimes useless, others easy to convert when you can get the passwords. Full coverage,usb, lsb, am, cw.
harris RF3200, sailor RE2100 receiver/exiter, control unit furuno FS1570.
To support the floor a little, 4x8" I, floor is a double layer 1.5" thick
Name:	app rf3200.jpg
ID:	337149   Click image for larger version
Name:	app re2100.jpg
ID:	337150   Click image for larger version
Name:	app furuno fs1570.jpg
ID:	337151   Click image for larger version
32 Volt Radios Dennis Craft Delco and other Low Voltage DC Light Plants 20 04-11-2017 02:38:44 PM
About those 32 volt radios...... George Andreasen Delco and other Low Voltage DC Light Plants 2 04-05-2017 09:17:48 PM
