Broke off tap. Need help!
this thread has 24 replies and has been viewed 4079 times
Old 05-10-2014, 10:32:43 PM
Default Broke off tap. Need help!
All, broke off a tap in threaded hole on my 1 hp Famous. What's the best drill bit to use to attempt to drill it out? Thinking a diamond tip bit would be best. Any thoughts appreciated. Size is about 3/64" - 1/8".
Old 05-10-2014, 10:40:15 PM
TekNik TekNik is offline
Default Re: Broke off tap. Need help!
A few Questions:
What size tap is it?
How deep in the hole is it broken off?
Is there part of the tap above the surface?
Is the fracture parallel to the surface?
TekNik
Old 05-10-2014, 10:51:25 PM
Ryan McClenahan Ryan McClenahan is offline
If your going to drill it out you need a carbide drill. Diamond is for masonry.
Old 05-10-2014, 10:56:28 PM
Black Eagle Black Eagle is offline
I've had success with one of these tools before. http://www.waltontools.com/products/remvtap.htm remember to use plenty of oil.
I've also used nitrogen to cool the tap then shatter it with a center punch.
Alternatively if you have a micro torch you can heat the tap to anneal it then drill it out when cool.
The Following User Says Thank You to Black Eagle For This Post:
Old 05-10-2014, 11:37:26 PM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
find a machine shop with a wire edm would be best.
I have had some success with breaking them up with a punch but you're working in a small hole.
Most taps will evaporate if a cutting torch is used on the larger ones.
Old 05-11-2014, 12:00:20 AM
go to the enco website and get a tapout
Old 05-11-2014, 12:20:16 AM
Years ago my boss took one out of a delicate spot with a handfull of carbide burrs in a dremel tool, with a steady hand. they had already busted a tap extractor. In the end of a crankshaft. Cleaned it up, put in a new bolt, and worked fine.
Old 05-10-2014, 11:04:06 PM
Paul Richardson Paul Richardson is offline
Not really sure why you would need a special type drill Kevin? Am I right to think the material will be either brass or mild steel?
My favourite method with bolts and studs is to make them look like a broken off tap spigot in the hole by drilling the center out as near to the thread as I can get.
After that I insert a small hand held hacksaw blade saw.Sometimes I need to reduce the height of the blade on the bench grinder to allow it to fit the hole.
I section the remains of the bolt or tap,in two three or sometimes four sections,taking best possible care to saw TO the thread and not through it.
I then use a small hammer and punch perhaps like a broken then resharpened scriber and very gently punch from the edge inwards to break out the first willing section.Minor damage to the host thread can usually be renovated ok with a tap.
Don't rush,be gentle,and sometimes a plumbers torch is a great help.I get great results when the job allows that method.
The Following User Says Thank You to Paul Richardson For This Post:
Old 05-10-2014, 11:15:28 PM
ssimntih's Avatar
ssimntih ssimntih is offline
I usually use carbide end mill, if you have the luxury of owning a mill. You definitely need something harder than the tap.
Old 05-11-2014, 08:33:31 AM
Nick's Avatar
Nick Nick is offline
Forget all that stuff about drilling and tap extractors. With a tap that small you have 2 choices. First would be to find a shop with a tap burner. Second is to find someone with a milling machine who knows what they are doing. A good machinist and a carbide end mill will get that tap out. May need a thread insert installed if breaking the tap damaged the hole but at this point your part is salvageable.
I broke it Patrick62 Welding Shop 15 08-07-2012 08:17:08 PM
If it ain't broke don't fix it? Bigjoedo Hit & Miss Gas Engine Discussion 6 10-15-2010 06:45:42 PM
Fix my generator! It broke! pegasuspinto Generators & Electric Motors General Discussion 20 08-01-2009 03:44:24 PM
My BALL is broke...can you help me fix it? jeffbaker2007 Oil Field Engines & Related Equipment 3 10-20-2007 08:03:30 AM
It was broke , so I fixed it Paul Spence Antique Engine Archives 3 02-23-2004 05:35:51 AM
