Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
A Hit And Miss Engine Throws A Belt
this thread has 3 replies and has been viewed 984 times
Old 06-12-2018, 06:18:57 PM
David Cave David Cave is offline
Default A Hit And Miss Engine Throws A Belt
I was running an engine on my dyno with a flat belt not tight enough. When a flat belt slips it's almost impossible to keep it on the pulley. You can actually see the belt running curved as slippage tries to run it off and the crown effect tries to keep it on.
https://www.youtube.com/watch?v=GBBzrP7MRc8
The Following 2 Users Say Thank You to David Cave For This Post:
Old 06-13-2018, 03:32:16 PM
Exclamation Re: A Hit And Miss Engine Throws A Belt
A common problem, especially if under a heavy load - tight or not. Often a set of guide stakes are put into the ground, near the engine, so as to keep the belt in line. Another method is to cross the belt. not sure if you can run your device backwards though.
Old 06-13-2018, 07:44:51 PM
Default Re: A Hit And Miss Engine Throws A Belt
Thanks Andrew. Yes if I was outside I would stake it. It's summer in Phoenix so I'm inside. I have an earlier video building the dyno followed by one running and calibrating the dyno. That second video shows the two bars I use to keep things from moving around. In this case I just forgot to tighten the belt after I made some changes. I thought it was interesting that you can actually see the belt curve so I put it up as a video. The dyno will run backwards but I would have to do a little rewiring.
Old 06-13-2018, 08:35:01 PM
Mike in NC's Avatar
Put a half-twist in the belt. Meaning one end the belt is right side out and at the other end it would be inside out. It would still be running in the same direction as in your video.
SmokStak Member #28
Advice needed on polishing steel crank throws Martin Reed Hit & Miss Gas Engine Discussion 13 12-27-2013 10:12:35 PM
Tractor pull throws a block (probably OT) NDmeterman YouTube Old Iron Videos 3 08-11-2012 03:23:38 PM
6.5 NH hunts and throws oil sharn h. Onan Generators 2 07-17-2009 10:11:51 AM
Stover CT2 throws oil at both ends of crank Larry Carlston Hit & Miss Gas Engine Discussion 16 09-28-2007 06:57:09 AM
The Mogul Runs! Hit & Miss,Miss,Miss, Miss,Miss Dan Bogart Antique Engine Archives 7 06-24-2003 12:10:08 AM
