It was broke , so I fixed it
this thread has 3 replies and has been viewed 1605 times
Old 02-22-2004, 09:34:30 AM
Default It was broke , so I fixed it
The mixer on my 1HP IHC Titan Jr. engine had a broken mounting ear(piece was missing), as well as the complete choke plate assembly. What is one to do except make it right. Took some scrap 3/16 flat stock from the cut-off box and made a rough cut to size on the band saw after I punched a hole in it. Took the MIG welder and welded it together. Then with the trusty Makita 4" grinder. I shaped it to make it look right(upper right ear in the photo) . After that project, I made the choke plate from some 3/16 round stock and scrap sheet metal from the sheet metal scrap box. It took two tries to get the plate so it would function right with a spring I made from some paino wire to keep it normally open, but I got it. Not 100% perfect , but when installed on the engine, who can tell . Paul , just having fun in NJ , and keeping busy in the shop .
Old 02-22-2004, 03:40:36 PM
Jim Tremble
Default Re: It was broke , so I fixed it
Good job, Paul. How many breaks did it take to get the job done ??
Jim
Old 02-22-2004, 11:00:27 PM
Dave Showerman
Paul, I'd have to say "you're pretty handy". PS Keep having fun. Dave in Holt.
Old 02-23-2004, 05:35:51 AM
Jim: I didn't use a "BREAK" on this job. I bent everything by hand Paul
If it isn't broke, fix it until it is? preskitaz Onan Generators 18 12-13-2017 11:37:13 PM
Broke off tap. Need help! Kevin Weis Hit & Miss Gas Engine Discussion 24 05-12-2014 05:07:28 PM
I broke it Patrick62 Welding Shop 15 08-07-2012 08:17:08 PM
If it ain't broke don't fix it? Bigjoedo Hit & Miss Gas Engine Discussion 6 10-15-2010 06:45:42 PM
