Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
Hit and Miss Engine Dyno Dynamometer
this thread has 4 replies and has been viewed 867 times
Old 06-11-2018, 07:00:50 PM
David Cave David Cave is offline
Default Hit and Miss Engine Dyno Dynamometer
I love to hear engines bark under load and also to demonstrate how a hit and miss works. I have 2 videos, the first discusses the principals then builds a small portable, calibrated dyno made from a treadmill motor. The second runs an engine at various loads and calibrates the dyno.
https://www.youtube.com/watch?v=heFTZiWnGDo
https://www.youtube.com/watch?v=B8tcTBM-2CA
Hope you enjoy them.
The Following 8 Users Say Thank You to David Cave For This Post:
Old 06-11-2018, 07:35:56 PM
Default Re: Hit and Miss Engine Dyno Dynamometer
Interesting, you put a ton of effort into setting all that up. Thanks for your effort.
Old 06-11-2018, 10:51:00 PM
Actually not a lot of effort. You could do the whole thing in a weekend. The wiring diagram is two wires and the efficiency is on the motor label. What took time - I spent weeks trying to make an old 1920's Delco light plant be the generator. They just don't have enough power so finally I gave that up and switched to the treadmill motor. The beauty is that I can now load on engine up to near max power and let her bark. I love the sound.
The Following User Says Thank You to David Cave For This Post:
Old 06-12-2018, 10:49:54 AM
Jim White Jim White is offline
Very nice display and you did an excellent job explaining the "technical' data.
Your old teacher days?
Old 06-12-2018, 12:31:40 PM
Thanks Jim. At engine shows around here, for the most part, engines are run at 1 RPM above dying and no load. I wanted something to really demonstrate a hit and miss engine at shows. The load needed to be relatively small and light and portable so that by my self I could load it in my pickup. Almost forgot, it needed to be inexpensive otherwise my wife would complain.
Petter AA1 Engine With Dyno YellowLister Vintage Diesel and Oil Stationary Engines 8 03-18-2018 07:05:13 AM
Portable dynamometer for shows Martin Gaudet Hit & Miss Gas Engine Discussion 25 04-07-2013 09:31:49 AM
Me and Dad and B JD on the dyno Randy L Peterson Antique Farm Tractors 0 05-24-2009 11:48:08 PM
Engine Dyno Sky Hit & Miss Gas Engine Discussion 3 01-27-2006 08:59:39 PM
Small Hit & miss engine Dyno. Dave Showerman Antique Engine Archives 2 07-11-2000 04:38:32 AM
