Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
Jaeger 2HP engine (almost) First Run
this thread has 2 replies and has been viewed 597 times
Old 07-30-2018, 04:02:16 PM
JF671 JF671 is offline
Default Jaeger 2HP engine (almost) First Run
1921 Jaeger 2HP engine, on it's second extended run after many unloved years. Surviving disassembly and a fire which burned out the PTO side crank bearing insert seats, this engine was little more than a block when it was acquired. Being a bit unusual, at least as Hercules engines go, I figured it was worth saving and gathered parts from another disassembled Model E and pieced it back together during the AGSEM's June show in Vista. I did take a couple of pics once I had the bare block cleaned, but I was too wrapped up in the reassembly to remember to take other pics.
Name:	Jaeger 2HP.1.jpg
ID:	315286   Click image for larger version
Name:	Jaeger 2HP.2.jpg
The Following 2 Users Say Thank You to JF671 For This Post:
Old 07-31-2018, 12:10:11 PM
OrgWayne OrgWayne is offline
Default Re: Jaeger 2HP engine (almost) First Run
OOOO you have a lot of Stuff around there Can I ask what the old car is ??
Wayne
The Following User Says Thank You to OrgWayne For This Post:
Old 07-31-2018, 03:41:03 PM
1904 Olds, repowered with a FM Z engine
The Following User Says Thank You to JF671 For This Post:
See if you can help with a Jaeger 5hp engine daydk1 Hit & Miss Gas Engine Discussion 13 03-06-2009 12:16:36 AM
My first engine (3HP Jaeger) Elwood Hit & Miss Gas Engine Discussion 30 01-25-2009 10:07:07 PM
jaeger engine Steve Kreiner Hit & Miss Gas Engine Discussion 2 05-03-2006 09:48:42 PM
Jaeger Engine Monroe Johnson Hit & Miss Gas Engine Discussion 1 09-20-2005 11:16:23 PM
Jaeger engine Selina M. Knight Antique Engine Archives 1 09-12-2003 05:48:43 AM
