Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
Monitor HJ 5hp Buzz Saw 1st Run in 30 Years
this thread has 3 replies and has been viewed 591 times
Old 07-24-2019, 03:38:53 PM
OTTO-Sawyer's Avatar
Photo Monitor HJ 5hp Buzz Saw 1st Run in 30 Years
Spent a few days digging my 5hp Monitor Saw-rig out of its THIRTY YEAR Hibernation.
Being the first it's seen Daylight in 30 years it needed a little tinkering like substituting a 12 volt battery for the old Dead 6 volt and then fiddling with the points with current applied to them to get them vibrating to get the Buzz Coil Buzzing, but other than that it was good to go and fired up on the second turn of the crank.
Needs a little fine tuning yet, but I'm happy it runs as good as it does after setting all these years.
https://youtu.be/6RHdxln58bc
Name:	6-18-2019 Pix. .   (58).jpg
ID:	339867   Click image for larger version
Name:	7-20-2019 Pix. .   (40).jpg
ID:	339868   Click image for larger version
Name:	7-21-2019 Pix. .   (30).jpg
ID:	339869   Click image for larger version
Name:	7-21-2019 Pix. .   (63).jpg
ID:	339870   Click image for larger version
Name:	7-21-2019 Pix. .   (91).jpg
ID:	339871   Click image for larger version
Name:	7-21-2019 Pix. .   (104).jpg
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
Old 07-24-2019, 04:21:30 PM
Photo Re: Monitor HJ 5hp Buzz Saw 1st Run in 30 Years
A few More Shots making my way out of the shed. . .
For Every 3-5 feet I rolled it ahead I had to use my high-lift jack to slide the rear end over 6-8 inches and roll a couple few more and slide another 6-8 sideways, but eventually I made it Out The Door and then using 5 loops of 12 Gauge wire I tied it on the the tow-hook on my car and pulled it around in front of the house.
Name:	7-22-2019 Pix. .   (18).jpg
ID:	339875   Click image for larger version
Name:	7-22-2019 Pix. .   (31).jpg
ID:	339876   Click image for larger version
Name:	7-22-2019 Pix. .   (41).jpg
ID:	339877   Click image for larger version
Name:	7-22-2019 Pix. .   (50).jpg
ID:	339878   Click image for larger version
Name:	7-22-2019 Pix. .   (57).jpg
ID:	339879   Click image for larger version
Name:	7-22-2019 Pix. .   (60).jpg
Old 07-24-2019, 05:14:47 PM
Vanman Vanman is offline
Default Re: Monitor HJ 5hp Buzz Saw 1st Run in 30 Years
That is VERY COOL to see the original equipment with it's engine! We see a LOT of old engines, but their machines are sadly scarce.
Keith
Old 07-25-2019, 05:53:14 PM
Junkologist's Avatar
Very nice! Sounds just like mine.
Mike
SmokStak member #146
monitor mower years built Clement Rook Jr. Maytag Engines and Collectibles 1 05-28-2013 03:08:13 PM
FB Buzz Saw AKMark Hit & Miss Gas Engine Discussion 8 03-01-2013 09:13:52 PM
Looking for Buzz Pat Barrett Hit & Miss Gas Engine Discussion 0 01-30-2011 08:29:43 PM
Buzz Box Rich Lehr Hit & Miss Gas Engine Discussion 3 03-06-2006 08:22:37 PM
Buzz saw Jerry Willis Hit & Miss Gas Engine Discussion 4 03-27-2005 11:21:29 AM
