Ihc M magneto gear
this thread has 2 replies and has been viewed 824 times
Old 06-12-2017, 02:33:18 PM
mag473 mag473 is offline
Default Ihc M magneto gear
Is the same gear used on the Bosch and IHC L magneto when installed on a 1 1/2 horse M? Thanks.
Old 06-12-2017, 03:17:00 PM
Mitch Malcolm Mitch Malcolm is offline
Default Re: Ihc M magneto gear
No it has the same # teeth and pitch but the bore for the shafts are different the bosch has a tapered bore the IHC has a straight shaft .. I do have both on hand ...
Old 06-12-2017, 04:04:47 PM
Thanks Mitch.
Magneto gear key doc8246 Hit & Miss Gas Engine Discussion 3 03-12-2016 09:26:59 PM
IHC L magneto gear question Kevin Weis Hit & Miss Gas Engine Discussion 3 12-03-2008 10:16:18 PM
Broken Magneto Gear on FM Tim Godwin Antique Engine Archives 1 02-03-2004 06:07:51 PM
F/M 25 tooth magneto gear Alex Fabiszewski Antique Engine Archives 2 04-20-2003 09:54:53 PM
WTD MAGNETO & GEAR A.J. TELOWICZ Antique Engine Archives 0 12-22-2002 04:55:01 PM
