Go Back   SmokStak > SmokStak® Shows, Swaps, Announcements > Shows and Swap Meets
Shows and Swap Meets Announcements, reviews, photos, movies and discussion about antique engine and tractor shows and swaps.
A new Little Movie
this thread has 2 replies and has been viewed 859 times
Old 04-10-2018, 03:08:52 PM
colo colo is offline
Default A new Little Movie
A new little movie
The Following 3 Users Say Thank You to colo For This Post:
Old 04-10-2018, 03:36:56 PM
Thumbs up Re: A new little movie
Thanks for the video! Lots of neat engines! I would not recommend starting an engine with your foot as in 16 seconds in - you could end up with a busted foot or even get launched into the air if the engine kicks back! The IHC M starting at 2.58 needs to have some work done on the governor or intake system (excessive intake valve stem leakage, bad mixer gasket, broken mixer venture or sticking governor collar and or linkages). The M is not hit and miss, it is a throttler, and should run smoothly like a modern day engine, when set up properly. Where was this show?
Old 04-10-2018, 03:57:46 PM
Default Re: A new little movie
In Italy:
https://www.google.com/maps/place/Va...11!4d10.036794
The Following User Says Thank You to colo For This Post:
8-16 IHC in Wonder Woman Movie primerk5 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 11-10-2017 10:10:45 PM
old movie on tv with movie steam Ron Davis YouTube Old Iron Videos 1 10-03-2012 07:15:31 PM
Movie--Get Low Kelly Reynolds Hit & Miss Gas Engine Discussion 17 07-13-2012 01:00:31 PM
6 HP Otto Movie Tom Winland Hit & Miss Gas Engine Discussion 6 01-17-2011 06:01:36 PM
Superior 25 H.P. Movie Fred Van Hook YouTube Old Iron Videos 0 09-19-2010 07:10:07 PM
